Longer Wheel Stud
Sep 2, 2002 | 10:47 AM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Longer Wheel Stud
What length wheel stud do I need for the rear wheels? Putting on the Weld 15 x 10's.
Will these do the job?
http://www.lingenfelter.com/lingenfe...=14&pf%5Fid=34
Sep 2, 2002 | 11:11 AM
Re: Longer Wheel Stud (Mr Mojo)
frank are you going to put them in yourself?
Sep 2, 2002 | 11:12 AM
Re: Longer Wheel Stud (QuickVet)
I'm going to attempt it, I 've done it on other cars, but I'm hearing they are a pain on the C4.
Sep 2, 2002 | 06:23 PM
Those are the same studs that I use with my 15 X 10 weld wheels.
Sep 2, 2002 | 07:48 PM
Frank, those will work fine. Let me know if you need a hand putting them in. :cheers:
Sep 3, 2002 | 05:30 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Longer Wheel Stud (NJVetteGuy)
Frank, those are the same as mine and they are not long enough. :(
Sep 3, 2002 | 08:05 PM
Re: Longer Wheel Stud (mackeyred96)
They will end up flush with your Welds, and this is not long enough for NHRA.
I put these on based on a previous thread on the forum, and it was my mistake because I didn't research it enough.
They are not hard to install however, just have to rotate the hub and find an open area in the back to get the new stud started. I then used a socket and a lugnut to suck the new stud in.
Regards
John
Sep 4, 2002 | 11:44 PM
Re: Longer Wheel Stud (Bowtie8)
Frank,
I agree with John, once you add the 5/16 spacer they're still to short but better than the stockers.
Dave
:sad:
Sep 5, 2002 | 02:10 AM
Maybe I'll buy two sets and crazy glue them together! :crazy: :crazy: :crazy:
