Lightweight Battery Options...
I have been looking at this battery
http://products.batterytender.com/Ba...t-Battery.html
Voltage: 12V
Lithium Cranking Amps: 360
Lead-Acid Replacement Range: 21-24(Ah)
Case Dimensions: 6.49” (165mm) length x 3.38” (86mm) width x 5.11” (130mm) height
Operating Temp: 40 - 140°(F)
Weight: 2.6 lbs
Also looking at this one
Voltage: 12V
Lithium Cranking Amps: 480
Lead-Acid Replacement Range: 26-35(Ah)
Weight: 3.75 lbs
The car will never see cold weather driving and will be stored in heated storage in the winter.
Voltage: 12V
Weight: 2.6 lbs
Voltage: 12V
Weight: 3.75 lbs
Voltage: 12V
Weight: 2.6 lbs
Voltage: 12V
Weight: 3.75 lbs
