Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Diff Gearing
Old Oct 31, 2018 | 11:11 AM
Fly N Low's Avatar
Fly N Low
Default Diff Gearing
Have an 06 M6 using the car mostly for street with some Drag Strip use. I have recently done headers and cam etc. and is now at 448 whp. I'm scared of rear diff problems so I'm considering RPM Transmissions kit to change out the rear. I plan to use drag radials in stock size 305/35/19 because I have a set of spare wheels for that. My question is what gear ratio should I put in it 342 373. 390. Or. 410
Old Oct 31, 2018 | 11:39 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
4.10 don’t fear the gear! I had them in my 6 speed car and loved them. Good for the strip and crazy fun on the street.
That said, unless you’re using the stock clutch, I would highly recommend using a bias ply tire.
Old Oct 31, 2018 | 12:10 PM
Fly N Low's Avatar
Fly N Low
I'm just getting back into this from old school drag racing days. Not sure about the choice of bias vs radial deal. Also was planning to put in a new stock style clutch since I don't have any crazy power and low budget. Your thoughts?
Old Oct 31, 2018 | 12:23 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
The issue with aftermarket clutches, is that they typically grab harder. That induces wheel hop which breaks rear ends, axles, and transmissions.
The bias ply tire is a lot more forgiving in those instances. The downside of running a bias rear, is that you really need to run a bias front tire as well. Just added expense.
Best of success with your goals!
To Diff Gearing
