Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Dana 44 conversion problems..........
Old Oct 30, 2002 | 01:22 PM
DRAGRACR's Avatar
DRAGRACR
Default Dana 44 conversion problems..........
Here is the link from my original post.
http://forums.corvetteforum.com/zerothread?id=422718
:seeya
Old Oct 30, 2002 | 03:41 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Dana 44 conversion problems.......... (DRAGRACR)
This is a bolt in swap, I don't understand :confused:
Old Oct 30, 2002 | 03:56 PM
DRAGRACR's Avatar
DRAGRACR
Default Re: Dana 44 conversion problems.......... (mackeyred96)
Well at first I thought that the torque arm was bent, so I got another one, and they were the same. The only thing that I can think of is that they sent me the wrong driveshaft, maybe a 4+3 or something. I don't know if they are the same length or not.
Old Oct 30, 2002 | 09:18 PM
hookedup's Avatar
hookedup
When I did my conversion I seem to remember more than 1/4" difference in driveshaft length between the A4 & 6M. I'll measure my spares tomorrow if you need it.
Dave :confused:
Old Oct 30, 2002 | 10:29 PM
Eric Fischer's Avatar
Eric Fischer
Hmmm,
Sounds like the driveshaft is too long.
Are you sure you need to change the driveshaft? Mackey did you change yours when you did the swap?
Old Oct 31, 2002 | 10:07 AM
DRAGRACR's Avatar
DRAGRACR
Default Re: Dana 44 conversion problems.......... (new92racer)
I got the rearend out again last night, and the driveshaft is too long. It measured 27 1/2 from center of the UV joint to center of UV joint. Looks to me that it needs to be about an inch shorter.
Old Oct 31, 2002 | 02:46 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
But how would that keep it from turning? Would should have marked the original one while in the car then you would have known how far this one was entering the tranny.
Old Oct 31, 2002 | 03:04 PM
DRAGRACR's Avatar
DRAGRACR
Default Re: Dana 44 conversion problems.......... (ski_dwn_it)
I talked with Sean @ Corvette Salvage and come to find out they sent me another auto driveshaft. Thanks for the replys. :seeya
Old Oct 31, 2002 | 10:15 PM
hookedup's Avatar
hookedup
First time I tried to put my D44 in someone had posted you could use the D36 driveshaft. Wrong, it bottomed out in the trans. Switched to the 6M driveshaft, no more problem.
Glad you got things solved DRAGRACR.
Dave :cheers:
Old Nov 1, 2002 | 10:08 AM
DRAGRACR's Avatar
DRAGRACR
Thanks. The driveshaft should be in today. :cheers: :cheers:
To Dana 44 conversion problems..........
