Driving technique
I got a my first Vette a couple of months ago, a C5 convertible with less than 50,000 miles on it. It makes me smile a lot!
I've never done any official drag racing. Was watching the open night at zMAX Dragway last summer and one of the guys mentioned driveline breakage, apparently from bad launching procedure. I want to try out the C5 on the strip soon but don't want to have to tow it home. I watched some intro to drag racing videos last night but didn't find anything that covered some of the finer points. My questions would be:
1. What driving error(s) commonly causes driveline failure?
2. Do you need to use the brakes when you warm up the tires in the burnout box? If so, do you just move your left foot quickly from the clutch to the brake or do you do like a heel-toe with the right foot on the gas and brake?
3. I've always read about sidestepping the clutch but the videos I watched didn't seem to advocate that. What's everyone's preferred technique?
4. Any good threads or videos I should look up that will answer my questions and more?
Thanks,
John
Stock clutch, stock tires;
Do not side step the clutch. Releasing the clutch pedal quickly while feeding it gas works rather well. Starting around 3000rpm. Tire pressure round 20-22. You will spin OEM tires due to the stiff sidewall. The trick is to limit the spin as much as possible. (Duh).
Traction control off. Active handling on.
For the burn out, when you’re tires are wet, it’ll be a lot easier on the drive train when you release the clutch pedal at about 4000rpm and quickly step on the brake pedal. The first time I tried it, I stalled.
you’ll figure it out after a few attempts. Have fun, be safe... it can be addictive.
http://www.rangeracceleration.com/06_Z06_DRs.html
Thanks,
John
2)You hold the brakes only hard enough to keep the car from rolling forward during your burnout. On street tires I NEVER went through the water. You'll never get the water off the tire and will just spin on the launch. I did a dry 1st gear "rolling burnout" (I coined the phrase) where I'd rev up to about 3500 rpm's and dump the clutch and feed throttle to keep the rpm's at about 4500-5000. I'd hold the brakes just for a second or so, then release them while holding the rpm's still and have the car spin and roll forward till I got near the staging area. By then the tires were plenty warm and cleaned for street tires. No billowing burnouts on street tires.
3)As mentioned above, dumping (what I think you mean by side stepping) the clutch is a no-no.
4)Ranger's video should help you.
Good luck!
Ron
