Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
trailering question
Old Jun 15, 2004 | 07:17 AM
93 ragtop's Avatar
93 ragtop
Default trailering question
I have a 93 c-4 and would like to know what you suggest to hook the straps to when trailering. On the front I went around the section of the frame that extends up to the radiator support. On the rear I went around the lower control arm and criss crossed the straps. I worry if this configuration is hard on the car.
Old Jun 15, 2004 | 08:14 AM
C5 CU's Avatar
C5 CU
Default Re: trailering question (93 ragtop)
i do not have a trailer but my car has been trailered several times and the criss-cross rear tie down as you described is a must to keep car from shifting sideways...my guess is you are very observant and have a good system figured out...good luck.
Old Jun 15, 2004 | 09:23 AM
93 ragtop's Avatar
93 ragtop
Default Re: trailering question (C5 CU)
Thanks for your input. My concern is if it could damage anything under the car.
Old Jun 15, 2004 | 09:34 AM
CFI-EFI's Avatar
CFI-EFI
I also have not personally trailered my C4. But I would think that on the rear, you'd be better off if you could find something on the chassis to connect to. I think if the tightening of the straps compresses the spring, somewhat, you'll get more down force. Criss crossing the straps is good.
RACE ON!!!
Old Jun 15, 2004 | 11:10 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
On the C5 the four jacking points are also shipping hook points where I put in a t-hook and strap it to the hooks. Not sure if the C4 has these. Sorry.
Old Jun 15, 2004 | 01:43 PM
Marlin in Minn's Avatar
Marlin in Minn
Default Re: trailering question (REDGAR)
The C4 also has those shipping tie down points that can be used with T-hooks. They are behind and to the inside of the front wheels....and in front of and to the inside of the rear wheels.
I know several guys with open trailers that use these, but I have an enclosed trailer so they would be hard to reach. I just do the back on the lower control arms and the front on the lower A arms..
Old Jun 15, 2004 | 02:10 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Default Re: trailering question (Marlin in Minn)
I attach the axle straps to each lower A arm and X them. Same at the rear. Tie TIGHT.
HTH
Old Jun 15, 2004 | 03:05 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
That's what I do with my open trailer.
Matt383
Old Jun 15, 2004 | 10:30 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: trailering question (Matt383)
I have an open trailer and use straps that connect to the wheels. A big towing service in Maryland recommended them to me. About 5000 miles/30 trips of towing in the past year with 0 problems.
Old Jun 16, 2004 | 02:11 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Thats where we hook mine when I need a flat bed.
Old Jun 17, 2004 | 03:08 PM
93 ragtop's Avatar
93 ragtop
Default Re: trailering question (mackeyred96)
Im going to look for those factory tiedowns. I have rented a u-haul trailer before and the over the wheel straps are nice. But I havnt been able to find those anywhere for sale like they have. Again Thanks to everyone for their input.
Old Jun 17, 2004 | 08:51 PM
JerryL's Avatar
JerryL
93 ragtop,
I got my straps from BA Products Company, 8925 McGaw Ct. Columbia, MD 21045 http://www.baprod.com Toll Free: (800) 327-3301. They have both kinds of straps.
Old Jun 18, 2004 | 03:56 PM
Bill Wilson's Avatar
Bill Wilson
I have a '94 Coupe and use axle straps attached in the front around the lower "A" arm then I "X" them across the trailer. In the back I use the same type of axle strap and attach it around the lower control arm but I do not "X" the rear straps. I use to "X" the rears but the strap would rub against a spot on the rear of the Vette and started to wear on the strap. Bought new straps to use in the rear and I have had no issues since.
I even got to involuntarily test the tie down method this past March when towing up to Englishtown on I-95 a merging car hit the brakes in front of me and I couldn't get the track/trailer/Corvette stopped in time. Hit the guy doing about 40 MPH - bent the hell out of the front bumper on my Ford 150 P/U but Corvette and trailer stayed together and safely behind me. P/U and trailer got towed away and I drove the Corvette home. I'm not suggesting this as a testing method but I'm confident the straps will hold.
Old Jun 18, 2004 | 10:05 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Over the wheel work great!
To trailering question
