Corvette Challenge Rules at E-Town
Maybe CFI-EFI can chime in since he has the rule book memorized. Or even if Mackey is reading this, I'm sure he would know the answer.
All I know is that C4's ruled today!!!!!!
I think you are correct in calling it a "competition SINGLE", and not a "competition BYE", and I do believe that, per NHRA rules, once a ladder has been drawn-up, and pairings made, a "competition single" was in-order.
I think you are correct in calling it a "competition SINGLE", and not a "competition BYE", and I do believe that, per NHRA rules, once a ladder has been drawn-up, and pairings made, and "competition single" was in-order.
That's correct guys, thats what should have happened if your competition was unable to make it to the line. The only think we do is give that person every oppertunity to get the problem fix and that sounds like what happens.
Remember some of these lanes guys running the lanes at the track couldn't run a lane at a bowling alley, most of you racers know more than they do, so hold your ground.
Vic
A month or so ago, my competition was DQed for a leak, at or just beyond the burn out box. I was told to wait while they advanced the next car. That was so WRONG. I would have been in the tower in a hot second, had I not won. As it was, I brought it up to the track manager, in an e-mail, the following week. He confirmed that the pairing had occurred as we left the staging lanes, and that I should have been on a single run.
The BIG problem with mistakes like this, is that it has a subtle effect on the final out come that can never be corrected. Had I not eliminated the "substitute" car, he might have won his legitimately paired race. If I had lost, and argued myself into a "reinstatement", either the guy I raced or the guy he SHOULD have raced, shouldn't have advanced, and on down the line.
The track can "make it up" to the wronged party, but the true out come of the event, is at least, "tainted".
RACE ON!!!
Boy could I tell you a story... Some already know about it...
Thanks, I feel better now.
If they numbered the cars the track official under the tower is to check for that.
You can't always trust the track to get it right, Guys will alway jump lanes to try to get an advantage.
I will address this with David this week
And PLEASE get them to adopt the NHRA Stock rules so we can race these cars properly. The inspection tech said he hasn't even heard of the NHRA changes. What's up with that?
Joe, I have noted your scenario and I am sorry you lost that opportunity. I am not sure where it went bad but I see your supposed oppent went four pair ahead of you so it had to be real bad.
As for the "pure stock", I asked again yesterday and was told again, "not until next year". Sorry. I cannot tell RP how to run their business. I can only make suggestions and I do.
Tip:
As I go around the wall and under the bridge, if my opponent is not "paired with me", I tell the official, or point to the car I should be with.... Usually before we get waved on to approach the starting line, the official under the bridge makes sure you are paired with the proper car....So unless a car pulled over, or didn't leave the lanes, that may be why all the confusion??
Anyway, as far as the NHRA Pure Stock rules go,
If you're an NHRA track, and "abide" by their rules, why the delay in implementing a "current" NHRA rule???
Obviously neither the track nor the racers can handle the pairings. My vote is to get rid of the pairings and just run whoever is in the other lane. Pairing the cars appears to be too complicated and if a situation like above is the end result then it needs to be avoided at all costs. Pairing the cars was result of people jumping lanes to avoid the heavy hitters. But guess what? You can simply count cars to figure out who your opponent is and move to another lane if you don't like your opponent prior to the pairs being assigned. So what does pairing the cars accomplish?
Also here's a hypothetical question for a track "official". Supposed the left lane car in pair 12 breaks. Does the right lane get a competition single? Or does he run the left lane from pair 13? Ask the "official" and see what kind of response you get...
As I have already stated, pairing the cars is too complicated and a waste of time. Just run whoever is in the other the lane. If it happens to be the points leader than so what, consider it an opportunity to shake things up.
You mean Pure Stock and the rule stipulates that it is up to the track to determine how and when to implement the rule. As a patron of the track and a person affected by the ruling you can make your desire to have the rule implement sooner by contacting the track.
I don't mean this in a negative way, but do these guys that run the lanes get any type of classroom training from RP? If they don't then maybe they should.
As for training, I don't know. I think there is so much going on at the track, that the likely reason that this happened to you Dave, is that the official may not have realized that we were on a ladder.
The competition single should happen only when a ladder is set. I do not believe pairings on the window counts as a ladder so if it had been before the ladder round, he may have been correct.
