Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
How flat is flat?
Old Jan 4, 2005 | 10:28 PM
brianw21's Avatar
brianw21
Default How flat is flat?
I'm writing a project paper on the 1/4 mile and cannot for the life of me find any information regarding how IHRA or NHRA certifies tracks.
So.... anyone have the requirements?
Most are 60ft wide.
I was thinking that 1% grade over the lenth was resonable, but then it dawned on me that this equates to 13.2ft over a quarter mile, os maybe not. I also assume that most require a concrete launch pad like 120ft? although most tracks are upgrading to 300+ feet.
I email and voicemaild both organizations and have got no response.
Specifics:
Minimum Length w/ Shutdown:
Minimum Length for Pre Stage:
Maximum grade deviation start to finish:
Maximum Grade deviation middle to side:
Road Construction: (8" base 3" Topcoat?)
Minimum Concrete Pad length:
Minimum Concrete side barriers:
Help would be appreciated.
Thanks guys
brian.weatherhead@wgint.com
Old Jan 4, 2005 | 11:17 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
You've already told me more than I knew. Good luck with the project
Old Jan 5, 2005 | 09:01 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Here is a link to a recent track built in our neck of the woods.
http://www.outerbanksspeedway.com/ne...504/new_track/
If you need more, I would contact them directly..........they should have all that data at their fingertips
Old Jan 5, 2005 | 10:56 AM
CFI-EFI's Avatar
CFI-EFI
The only spec I know is that the prestaged and staged beams are to be 7" apart. There has a tolerance (+ or -) to that spec. Give a call to the "New Crew", thay should be able to answer your questions. Unless they get the idea you are building a track to compete with them.
RACE ON!!!
To How flat is flat?
