Vortec v L98 Heads?
Old Feb 1, 2005 | 07:16 AM
rodj's Avatar
rodj
Default Vortec v L98 Heads?
Disregarding the obvious , weight and manifold choice; which would be the better head in stock form for a budget rebuild on a street 383.
113 L98 heads or Vortec.
The Vortecs seem to get good reviews as far as flow goes , valve sizes are same and chamber size doesn't matter as I have to buy new pistons.Have both heads and don't want to invest in AFRs just yet.
Old Feb 1, 2005 | 10:11 AM
comp's Avatar
comp
waiting to read this one
Old Feb 1, 2005 | 10:25 AM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
I'm definately not the expert, but when I wanted to convert a remanufactured '87 350 to replace a vortec for my '96 Suburban, the engine builder (Jasper Engines) told me it could be done by using the heads, intake, cam & lifters, timing cover, etc... from the original 96 engine. The tech said that the block was essencially the same (as long as it came with a factory roller cam to begin with).
I never ended up doing the swap, so I can't say if it would have worked in the real world or not.
Old Feb 1, 2005 | 11:11 AM
cv67's Avatar
cv67
St. Jude Donor '05
The vortecs make great torque! I would if I didn't mind iron heads. They won't make any huge flow numbers but would work great on a driver. Usually good for 40 ft/lbs.
Old Feb 1, 2005 | 01:18 PM
VetteNoob's Avatar
VetteNoob
I've always heard the Vortec heads flow better because of the design. Okinawa86vette (Chris) has a set of Edelbrock E-Tec 200 aluminum vortecs with low miles for sale if you're interested.
Old Feb 1, 2005 | 01:23 PM
comp's Avatar
comp
where ?????
Old Feb 1, 2005 | 03:22 PM
VetteNoob's Avatar
VetteNoob
Originally Posted by comp
where ?????
Where? are the heads or where I heard about vortec heads flow better?
http://customclassictrucks.com/techa.../0405cct_head/
http://www.edelbrock.com/automotive/headsbchev.html (With a grain of salt)
http://www.carcraft.com/techarticles/41598/index4.html
Old Feb 1, 2005 | 04:12 PM
comp's Avatar
comp
the guy that has them ??? and $$$$
Old Feb 1, 2005 | 10:59 PM
VetteNoob's Avatar
VetteNoob
Ahhhh..... Okinawa86vette (Chris) on the forum. He's in CO. Im not sure what he is asking for them, but definitely worth contacting him. I know Chris and he's a good guy.
Old Feb 1, 2005 | 11:28 PM
comp's Avatar
comp
OK why doesn't he like them ????
Old Feb 2, 2005 | 01:09 AM
VetteNoob's Avatar
VetteNoob
He does but he just bought a 383 long block from SDPC and it came with E-TEC 200 heads so now he has 2 sets.
Old Feb 2, 2005 | 01:37 AM
comp's Avatar
comp
find out the info and IM me
Old Feb 2, 2005 | 04:29 AM
silver84's Avatar
silver84
How much is the 'raised port' thing,
really worth, in terms of power?
Or, if you try hard, can you get 99 percent as
good with the old port locaton.
aftermarket support, is thin.
Old Feb 2, 2005 | 02:40 PM
comp's Avatar
comp
"normally" it is better because it give's a better shot at the valve for more flow
Old Feb 3, 2005 | 02:10 AM
rodj's Avatar
rodj
Meanwhile ,back on the farm, the question was.
What I was judging them by was the flow numbers.
L98 58 cc / 163cc intake. I 196 -E 155 @0.500 lift
Vortec 64 cc /170cc intake. I 239 - E 147 @0.500 lift
Note; Stock LT1 head only flows 214 @0.500.
(http://www.chevyhiperformance.com/te...98/index4.html)
I have both types , AFRs are $3000 in local pesos and I would like to get the engine running with the heads I already own and swap to TFS /AFRs later.
Old Feb 3, 2005 | 07:21 AM
comp's Avatar
comp
Hummmmm add a little port work to the vortec's
Old Feb 3, 2005 | 10:03 AM
CFI-EFI's Avatar
CFI-EFI
Don't forget that you need a vortec intake manifold for a head swap.
RACE ON!!!
To Vortec v L98 Heads?
Old Feb 4, 2005 | 01:11 AM
rodj's Avatar
rodj
That is why I said at the start
"Disregarding the obvious , weight and manifold choice;"
Old Feb 4, 2005 | 01:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
Wouldn't take much at all to make them flow well!
Old Feb 4, 2005 | 01:37 PM
comp's Avatar
comp
no it won't be that hard for a Torque motor
