Cool tool: Piston squareness checker
Old Mar 20, 2005 | 04:12 PM
ZD75blue's Avatar
ZD75blue
Default Cool tool: Piston squareness checker
http://www.muller.net/mullermachine/...ton/index.html
I thought that was a great "Simple" way to match your pistons to the bores in an ever more complex way than just slapping them in!
The video shows how its used...
Pretty cool!
Old Mar 25, 2005 | 06:09 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
that is cool *** tool.
Old Mar 27, 2005 | 11:37 AM
CFI-EFI's Avatar
CFI-EFI
I fail to see the point. From what *I* see, all this does is estabilish the relationship of the end of the pin bore to the widest point of the piston under the pin. The piston diameter is measured at 90* (major diameter) to the pin bore for cylinder fit . Pistons are NOT round. Unless I misunderstand, I don't see the significance if this measurement.
RACE ON!!!
Old Mar 27, 2005 | 07:57 PM
ZD75blue's Avatar
ZD75blue
If you have a piston that has no pin offset it lets you drop a piston that is ovaled the same way as the cylinder bore...
Just another way to standardize the clearances!
Old Mar 27, 2005 | 08:33 PM
CFI-EFI's Avatar
CFI-EFI
I don't understand. What do you mean by "drop"? If you mean, install, generally pistons have domes, dishes, or valve reliefs that dictates which way they they are installed. Oval cylinder bores??? A piston tends to center in the bore. Either the pin floats in the rod or the piston pin hole. Doesn't this just measure how far the end of the pin bore is going to end up from the cylinder wall? And if it's equal from side to side? I'm sorry, I just don't "get it".
RACE ON!!!
Old Mar 27, 2005 | 10:25 PM
2manyfuncars's Avatar
2manyfuncars
Default I don't get it
While I love tools I can't see any need for this one...
To Cool tool: Piston squareness checker
