Camshaft binding??
Old Apr 6, 2005 | 12:06 AM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Camshaft binding??
I just though of this as I did not really think about it initial as I was installed my roller cam in my ZZ4. The cam was rotating fairly easy until I seated it on the last cam bearing. From there, it seemed like it took a little bit more resistance to spin the cam. Is it possible that there is a misalignment in the cam bearings due to wrong installation . This is a brand new zz4 shortblock. The cam is a comp cams steel billet hydraulic roller. Thanks for any advise.
Old Apr 6, 2005 | 11:11 AM
CFI-EFI's Avatar
CFI-EFI
Occasionally. The first thing to do is pull the cam and set it up on a pair of vee blocks and check it to insure it's straight. Use a dial indicator to look for run out at all the bearing journals. The cam bearings can be line bored, if necessary.
RACE ON!!!
Old Apr 6, 2005 | 03:19 PM
NUckINg FuTS
Could it just be the assembley lube causing the drag??
Old Apr 6, 2005 | 06:28 PM
CFI-EFI's Avatar
CFI-EFI
I guess. I can't feel how bad it is from here.
RACE ON!!!
Old Apr 6, 2005 | 06:52 PM
NUckINg FuTS
I doubt that the camshaft is the problem because it spun easily up until the last bearing. Possibley a small nick on the furthest bearing causing a bind? If that is the case will running the engine wear in that bearing without damage?
Old Apr 6, 2005 | 08:12 PM
JCAIRE2's Avatar
JCAIRE2
No. What usually happens is the edge of the bearing will mushroom from the install tool and give a tight bearing. If the bearing is nicked, you'll end up with a spun bearing as soon as the engine is started. WHen the bearings were installed, a test cam should have been run into the engine and turned by hand to check the bearing install.
Old Apr 6, 2005 | 09:24 PM
NUckINg FuTS
What if a burred edge is the culprit? Would it be safe to run the engine that way?
Old Apr 7, 2005 | 12:00 AM
skid's Avatar
skid
Try it and let us know
Old Apr 7, 2005 | 02:10 AM
JCAIRE2's Avatar
JCAIRE2
NO in that situation, get some fine wet/dry sandpaper and lube it with a little oil and try to polish out the burr. Whatever is hanging up the cam will just be wiped into the bearing and destroy that journal.
Instal the cam and turn it a couple times. Remove cam and with an inspection light, look at the cam bearing for any shiny spots, those are the high areas. Polish a little with the sandpaper and wipe clean. Reinstall cam and repeat until it turns freely. There should be some resistance to turning, but no rough spots.
To Camshaft binding??
