Crank Trigger
I have decided to install a crank trigger to ensure the timing is rock steady. I wanted to run a small nitrous shot and I will feel more comfortable knowing the timing will not change.
That leads me to my inquiry: Has anyone here installed a crank trigger on their setup? After researching the different brands I have decided to purchase the kit from Mallory because it includes an easy to use adjustment mechanism for setting the timing.
Summit has it on backorder until this coming Friday so I won't get it until the following week. I will install it and report back on the installation and track results if anyone here is interested.
Thanks,
Travis
I looked all over this morning for the reference where i read this but could not find it. But some ign boxes tend to retard timing significantly with higher rpm and since ur dist is locked u can't adjust the wieghts and springs (advance curve) for this. If u have a spare dist that still has the mech advance set-up, u might just drop it in for a try. Jacobs used to sell a serious timing control for NOx and i still see its availible although the company is owned by Accel now (i think).Also i've read the best crank triggers are the ones with the sensor mounted to the flywheel/flexplate as the damper mounted triggers are open to road debris.
BTW i don't know if u need the dist housing and gear in place to ensure the cam oil galley press is maintained and the gear maintains cam stability? Or just cover the dist hole? Anyways this is interesting if it can eliminate that dist, so please post ur results.
cardo0
A distributor less system with coil-on-cylinder ignition would certainly be nice, but is way out of my budget!
