These Brodix Heads any good?
Old Jun 1, 2005 | 10:52 AM
Dougs 90's Avatar
Dougs 90
Default These Brodix Heads any good?
THESE NEW 23 DEGREE, IK200, (IRON KILLER) HEADS ARE ON THE BEST BARGAINS ON THE MARKET TODAY!
READY TO BOLT ON, with 200CC intake runners, ULTRA LITE CASTINGS, BRONZE VALVE GUIDES, valve seats for use with UNLEADED FUEL. ENDS MILLED & DRILLED for accessories, with STRAIGHT SPARK PLUG ANGLE in either, 64 CC or 72 CC COMBUSTION CHAMBERS.
They feature BRODIX 2.055 INTAKE VALVES, 1.600 EXHAUST VALVES, COMPETITION VALVE JOB.
CNC PORT MATCHED INTAKE RUNNERS.
COMPETITION CAMS HYDRAULIC ROLLER VALVE SPRINGS with 10 degree steel retainer & locks.
COMP CAM'S GUIDE PLATES & your choice of either 7/16 or 3/8 screw in studs.
They would be going into a superrammed, LT4 Hotcammed 350.
These are selling for $995, thought I would get an expert opinion on these.
Thanks,
Doug
Old Jun 1, 2005 | 11:48 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Do they list the flow numbers?
Old Jun 2, 2005 | 01:25 AM
Dougs 90's Avatar
Dougs 90
FLOW CHART cfm @ 28" H2O
VALVE SIZE 0.200 0.300 0.400 0.500 0.600 0.650 0.700
2020 INTAKE 123 181 230 253 261 261 262
1.600 EXHAUST 100 145 164 171 176 177 177
Old Jun 3, 2005 | 12:55 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
Looking at the exhaust numbers they are not much better than a factory LT1 aluminum head... The intake numbers are good but they seem stuffed up on exhaust side to me.
Old Jun 3, 2005 | 07:06 PM
Corvette Kid
My ported LT1 heads flow over 280 at .600" lift and even do 275 at .525" lift which is the maximum for my Hotcam. These just don't seem real stout for an aftermarket head.
Old Jun 4, 2005 | 02:12 AM
Dougs 90's Avatar
Dougs 90
AARRRRRGGGHHHH......
The search continues.......
Thanks,
Doug
Old Jun 5, 2005 | 01:00 AM
Russ Bellinis's Avatar
Russ Bellinis
Trick Flow 23* heads flow almost as well as AFR's at 1/2 the price. You won't find a better flowing head for the money. Get the ones with the dual valve springs, I think Summit sells them for about $1100.00.
Old Jun 6, 2005 | 05:07 PM
mike 1985's Avatar
mike 1985
I love my Canfields from competition products. $1055 delivered to my door with dual springs.
combo and times are in my sig.
Old Jun 7, 2005 | 12:10 AM
gkull's Avatar
gkull
I was not going to say anything, but i put alot of money into iron heads in the past with P&P...... only to have cracks appear outside the valve seats. On the other hand I had major valve damage to aluminum and they came back repaired by AFR and they were perfect.
I would never use iron again!
Old Jun 7, 2005 | 02:03 AM
korvetkeith's Avatar
korvetkeith
Interesting, i'm putting a vortec 350 in my car and was planning on spraying it eventually.
You can get those IK200s for $700 bare They are meant to be a bargain.
Old Jun 7, 2005 | 04:14 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Those heads aren't that bad, but I mean for the money I would run the Dart Platinum 200s on your ZZ4 shortblock.
.200 .300 .400 .500 .600
130 194 242 274 283
109 158 198 208 214
This should help your search:
http://users.erols.com/srweiss/tablehdc.htm#Chevy
Old Jun 7, 2005 | 10:37 AM
gkull's Avatar
gkull
Vortec heads are a **** poor design in the area of manifold sealing. My buddies automotive shop does 100's of them a year. Nothing like a little coolant in your oil or feeding through the cylinder after a few years of heat cycles. His shop loves Chevy. Mass market junk products to keep the mechanics busy. Oh - nice vacuum leaks also. They just don't have enough bolts holding the manifold on.
Old Jun 7, 2005 | 11:49 PM
korvetkeith
I used a vortec specific intake and intake gaskets. The gaskets are a hard plastic with rubber seals around all of the openings. The bolts for the intake are designed so that they bottom out and seal perfectly when used in conjuction with the correct intake gaskets. Everything I've read claims that this system works great.
Old Jun 12, 2005 | 09:49 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
we used them on a 350 malibu went from a ported set of 64cc 202 iron catings to the 64 cc ik head with the optional cnc combustion chamber et went from 12teens to 12.20s to 11.30s to 11.40s no other changes
to the door price was $1150
Old Jun 20, 2005 | 07:45 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
They outflow AFR 190's out of the box at .400 and .500 lift With minimal work, these will be outstanding heads.
Old Jun 21, 2005 | 09:18 AM
ylose's Avatar
ylose
220,000 miles on my K1500 truck (1st year of the Vortec TBI engine). And I still drive it like I stole it !
Old Jun 26, 2005 | 09:18 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
update on the ik heads on a 350 we changed to stronger springs and the car picked up
at 11.27 at a da of 3000ft you be the judge
Old Jul 15, 2005 | 05:40 AM
TIMSPEED's Avatar
TIMSPEED
DAMN! That's nearly a 100hp increase! WILD!
Old Jul 20, 2005 | 07:34 PM
Dougs 90's Avatar
Dougs 90
That is really good for a street car! You still trying these Steve? Those numbers sound great Cork! I found a set of AFR 195's from a member here so that is what I am going toss on top. I woulda tried them if I had known about those gains though, sound to be a real solid street head for not alot of dough!
Doug
To These Brodix Heads any good?
