From: Buy USA products! Check the label! Employ Americans
Originally Posted by KyRP2NITe Corvette
Ever Heard of PB Penetrant Oil? It is about 100x's more effective than WD-40... should be able to get it at NAPA or Autozone, White can with Yellow Cap and Red, Yellow and Black Labeling... great stuff! Soak it with that and if it doesn't come free you are probably just SOL...
That stuff is unbelievable especially if you let it sit over night. I use it on scaffold jacks which are a bitch.
My uncle restores antique tractors and has rescued many of a frozen engine by using a tranny fluid/kerosene mixture. May have to let the engine sit for a few weeks but this mixture works.
I've used Marvel Mystery Oil before with success.
But I definitely agree with the previous statements about the cylinder wall damage...that engine will never seal correctly on the rings again, and will use oil like that is its job.
PB blaster is a fine product, especially for trailing arms.
