Time for another conversion
Old Jul 9, 2001 | 01:24 PM
Mojo's Avatar
Mojo
My darned tranny started slipping while I was on my vacation this week. Four automatics is enough!!! I'm leaning toward putting a patch job on this tranny while I work on getting the parts for a 6 speed conversion.
Old Jul 9, 2001 | 03:02 PM
BOWTYE8's Avatar
BOWTYE8
I like what I am reading
No really sorry to hear you are going thru trannys like that. I remember a while back you burned up one after 2 weeks or after you first blast with it.
There has tobe some good trannys out there.
Phil,shalin,Some of the other top dogs running 700r4,4l60e.
Dennis
Old Jul 11, 2001 | 11:50 AM
Mojo's Avatar
Mojo
I got the final verdict yesterday. I burned up the 3rd gear clutch pack. The really sad thing is that I don't drive it hard that often. Shoot, I hardly drive it at all. It's always broken! Pro-built will rebuild my 700 with a good 9 1/2 inch lockup converter for about 2k. I'm wondering what a six speed conversion will cost. I think I have to have all of the parts from an '89 if I want to convert. I'm kicking myself for missing an entire conversion on Ebay yesterday that went for $1100.
Old Jul 11, 2001 | 12:47 PM
ralph's Avatar
ralph
Mojo, sorry to hear about your continued problems. 4 autos!!!! where are you getting these things??? a good rebuild should last a while longer then that!
I'm having as much trouble as you this year. Seems like my car has been apart more than it's been together. The lastest is a blown head gasket!!!
Dennis did you finally get your rear end back???
Old Jul 11, 2001 | 01:15 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
You can break 6-speeds too. You might try thinking about a TH-350 or TH-400. Should last a bit longer.
Old Jul 12, 2001 | 12:14 AM
HWoods's Avatar
HWoods
Mojo, I think a street Lenco is about $2600-2700. If I had the bucks, I would seriously consider that route. I have paid to have (3) 700r4's rebuilt. I feel your pain. Or maybe a Turbo 400 with a gear vendors over under drive attached. That's the route Callaway went
Old Jul 12, 2001 | 01:29 AM
samc's Avatar
samc
Mojo, is the 408 that much stronger than the 383? i dynoed 420 RWTQ last year, and have not killed my 700r4 yet. i had it rebuilt locally for $500 when i built the motor. probably 100 passes at the strip, mostly in the mid 12's, best was a 12.1. killed a D36 though
maybe i'm just lucky? or George knows how to build a 700r4... i've also got the stock converter and mobil 1 fluid, and a cooler in line with the radiator.
Old Jul 12, 2001 | 02:03 AM
11sec84's Avatar
11sec84
The auto to 6 speed change is a pain in the you know what. People have said sell the car and buy one with a stick. In order to do the swap you have to change the whole car. I'd consider the turbo 350 or 400 route. I went to a turbo 350 and it was pretty easy.
Old Jul 12, 2001 | 12:19 PM
Mojo's Avatar
Mojo
I've done auto to manual conversions before. They aren't *that* bad. You just have to make sure you have all of the right parts before you start. I'd love to do a turbo 400 with a gear vendors OD, but that's a lot of cash! If I could get my 700R4 rebuilt for the same price samc did it would be a no brainer! Of course, if I do stick with an auto, I'll *definitely* go with a good 9 1/2" lockup converter. Pro-Built transmissions recommended a good converter that's on par with the Vigilante, but $200 cheaper. I haven't entirely ruled out trying my hand at rebuilding my tranny myself, either. I've always wanted to learn how to work on an auto trans.
Old Jul 12, 2001 | 01:43 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Mojo there has been talk of people in the C3 section installing the Tremec TKO 5 spd into their cars. These trannys are rated to handle 500 ft/lb of torque I believe with the benefit of having a O/D gear in 5th.
Here's a quote from Monty in a recent topic:
I put a TKO in my '82 last summer. Sine my '82 came from the factory with a 700R4 and a removable crossmember, the install was pretty easy.
I got the clutch pedal assembly from Gruhala as well, and rebuilt it with new bushings, springs etc from Dr. Rebuild. I also used a spherical rod end (heim joint) clutch linkage kit from Speed Direct.
While the overall length of teh TKO/bellhousing combo is very close to the overall length of a 700t4, the tail mounting point is in a different location. Compared to the mounting points of a 700R4, and the mounting holes in the stock removable tranny crossmember, the mounting point for the TKO is about 4" forward. I made an adapter plate out of 1/4" aluminum. It was a temporary measure until I could get a braket made and welded to the crossmember, but it has held up just fine. Additionally, there is a triangular bracket used in Mustang applications on the tailhousing that I had to cut off. If you were to move the crossmember forward, you wouldn't need to cut it off. It's no big deal though, a Saw's All took it off in 5 minutes.
However, to back up the statement that overall, the TKO and the 700R4 are basically the same length, I could have used my stock driveshaft if I added conversion ujoints. With the tranny in place and the stock driveshaft, the tranny yoke only needed to be slide out about 1/4" to mate to the driveshaft. I ended up having Denny's Driveshafts make me a new driveshaft with new, larger tranny and differential yokes so I could run larger, stronger ujoints.
These tranny cost much less than a 6 spd & I believe handle more power. Something to think of before you shell out the $$ on a 6 spd.
Old Jul 12, 2001 | 02:05 PM
crznL98's Avatar
crznL98
I don't know what you want to do with your car, but I would consider the 6 speed. If you want specifics -- I'm right in the middle of cutting up my '88 and converting it to a ZF -- e-mail me at keithkoyano@yahoo.com.
KEith
Old Jul 12, 2001 | 06:51 PM
Smitty's75's Avatar
Smitty's75
If it was me and I was going to go to a stick, I would just get the Richmond 5 speed for about $1800-$1900 and say screw the OD, or maybe even a Super T-10 4 speed,,,NASCAR still uses them and they go to about 700-850 HP,,,I used to REALLY trash them years ago and NEVER broke one, and really, how many gears do you need for a quater mile! Sometimees you really have to look backwards to go forwards,,,,T-10, 350 Turbo, 400 Turbo and yes even, the old Power Glide, they can be built to take more HP than you can afford to buy!
Old Jul 12, 2001 | 07:29 PM
Mojo's Avatar
Mojo
Problem is that I like to drive the car more than just 1/4 mile at a time. Overdrive is essential. If I could afford a gear vendor's unit, that would be it! They're $2700!!!
Chris
Old Jul 12, 2001 | 08:22 PM
HighHopes85's Avatar
HighHopes85
I haven't really been on the forum long enough to know your tranny probs, but when I rebuilt a 700R4 (5 times to get it right ), each time I ended up getting upgraded parts. Pretty much all the sprags, carriers, etc I ended up using were from the year right before they went to the 4L60E. Don't know if this could be the solution to your problems or not. I got most of my parts from Jasper Engines and Transmissions mainly because they are a hop, skip, and a jump from me, but most smaller shops would likely be able to produce the parts for you. If you have already done this, I don't know what to suggest.
All I remember is I kept tearing up my darn 700R4 that I put in my Chevelle cause I kept messing up the 2-4 band pin (it always sheared off). That was 4 years ago and I am still trying to get the tranny fluid smell out of my hair -Matt-
Old Jul 12, 2001 | 08:26 PM
Mojo's Avatar
Mojo
Matt,
Did you do the rebuild yourself? I've had a local shop do all of my rebuilds, back in the day they were the best around. They built all of our stuff for us back when we were running 3 speed autos. We had great success back then, but we were never putting out the kind of power I am now. I'm wondering if I can't get by with replacing the 3/4 clutch pack and using a good converter.
Old Jul 12, 2001 | 08:55 PM
HighHopes85
Yeah, I rebuilt it myself, and chances are I wouldn't do it by myself again. Then again, I was only 17 and really just wanted to tear stuff apart without having to put it back together (correctly, at least). I learned a lot from it, especially since I made all the presses and vices out of a long piece of all-thread and a few 1/4" plates.
Needless to say, I really don't know just how much these trannys can hold, and I am definitely not an expert on them by any means. I've gotta hunt down the manual for IWANT2DRIVEMY85, so when I find it, I will at least send you the upgrade-parts list. -Matt-
Old Jul 13, 2001 | 02:42 PM
Warlock's Avatar
Warlock
Mojo, you better check http://cgi.ebay.com/ebaymotors/aw-cg...280191&r=0&t=0 quick before someone clicks "buy it now" on this one too.
To Time for another conversion
Old Jul 13, 2001 | 06:06 PM
Mojo's Avatar
Mojo
Unfortunately, I read in a conversion article that I have to have a ZF from an '89. The shifter is supposed to come out in a different spot on the '90+. Also, with no source of parts for the ZF, I wouldn't want one that needs work.
Old Jul 14, 2001 | 03:05 AM
vettewally's Avatar
vettewally
Try jimsperformance.com they will sell you th400 that will install in a vette.Or the parts you need to make one fit in a vette 1-877 465-9569
Old Jul 14, 2001 | 07:22 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
You can get ZF parts from a few different sources now. I won't mention what they cost though.
Rockland Standard Gear is the official ZF distributor. Parts are also available from Bill Boudreau - http://www.zfdoc.com/ or Kurt White - http://www.whiteracingproducts.com/home.
[This message has been edited by Red 90 L98 Coupe (edited 07-14-2001).]
