where's number 1????!!!
Old Jul 31, 2001 | 02:49 PM
want2drivemy85's Avatar
want2drivemy85
if you are looking straight down at the top of the distributor, where is no 1 plug wire in relation to the tach/batt hook up? i looked in chilton and haynes, they dont show it in relation to the hookup. im prety sure i dont have it hooked up right as i had a giant fireball come out of the carb and start a fire. help, please!!!
Old Jul 31, 2001 | 03:19 PM
-=Jeff=-'s Avatar
-=Jeff=-
typically...
from the Tach/Batt connection on the big Coil in Cap HEI. The # 1 is usually the second post counted clockwise from the TACH/Batt.
Also if the motor is sitting on TDC the Rotor should be pointing toward the #1 Cylinder..
Also make sure your rotor is not 180deg off from TDC
Old Jul 31, 2001 | 03:43 PM
want2drivemy85
thanks, i dont know what i was thinking earlier......just getting frustrated i guess. i just lined up tdc and went from there...thanks alot though!!
To where's number 1????!!!
