Engine Code Help
Old Dec 22, 2005 | 08:35 PM
harrin's Avatar
harrin
Default Engine Code Help
on a 71 corvette the casting numbers is 3963512,the code should be CPH,where do I find this code is it stamped or is it forged? Any help is appreciated
Old Dec 22, 2005 | 11:00 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Don't know why i look these numbers up as i'm not a resto minded enthusiest but its kind'a challenge as i have the books to do so.
CPH is a suffix code and its stamped at the end of the stamped engine code on p-side front of block that includes plant mfr, date and VIN.
Very possible that if eng has been rebuilt then the deck has been machined and the stamp removed or a eng rebuilders stamp applied.
A casting date code is in rear of block also and cast into block.
cardo0
Old Dec 22, 2005 | 11:11 PM
harrin's Avatar
harrin
cardo0
THE DATE CODE WAS L14 9
To Engine Code Help
