Canton RR oil pan question
Since your pan is used, it's possible someone removed the canton windage tray, in which case, you should be able to just use the stock one.
In any case, definitely test-fit the pan to make sure you have proper clearance on everything. Especially if you're building a stroker. You'll need to test-fit it anyway to make sure you have proper pickup-to-pan clearance. I forget what the gap is supposed to be, though.
Also, make sure the dipstick goes in properly with the pan and tray on. I had to drill a hole in my canton windage tray for the stock dipstick.
Just an alternative to buying new studs and having to retorque the main caps from under the car.
By the way, its a great pan ... love it
Road race oil pan w/ LT headers
I made several posts about installing a Canton on my L98. In this
case, I replaced the three windage tray studs with conventional
main cap bolts. I did not disturb the caps and even if I had (was
tempted to plasti-gauge them), I would not have been concerned
about R&Ring them. Re-torque with an accurate wrench and be done.
There are a few other L98 details in subsequent posts I made there that
might apply and be helpful, too.
Maybe PM ScaryFast to see how he proceeded.
Melling pump (p/n 10552) mentioned at the end of that thread.
In doing so, I discovered that there is a p/n 10552C version that comes
with some very nice extras for just $10 more. You need to confirm that
the 10552 is correct for you. But whatever pump you get, consider
the benefits of the 'C' option.
From Jeg's site
689-10552C
Note: The Anti-Cavitation models feature specifically machined grooves
in the housing and cover to reduce cavitation effects in high RPM
applications. The drive and idler shafts have also been extanded in both
the housing and cover, this eliminates dynamic shaft deflection at
increased RPM levels. The cover is doweled to the pump housing to
assure alignment of the shaft bores. The gears are billet steel and the
pump relief valve has a screw-in plug instead of a pin. The drive shaft
has a male hex drive with the corresponding female hex intermediate
shaft supplied. The pick-up screen hole is machined to use original
press-fit screens. The housing and cover are CNC-machined and then
coated with Manganese Phosphate for wear and rust prevention. A
stock pressure spring is also included to reduce bypass pressure if
needed. With this pump design, oil pressure is slightly reduced at idle.
Designed for racing applications only. Uses bolt-on style 689-12557
with 7'' deep pan, 689-12558 with 7.5'' deep pan, or 689-12559 with 8''
deep pan.
Now I can buy one already built right off the shelf for pocket change.
Let the good times roll.
