Knock Detector
Old Aug 8, 2001 | 05:24 PM
clearrun's Avatar
clearrun
Default Knock Detector
I am running a carbureted engine. Only electroinc is an MSD ignition box. Is there such a thing as a knock (preignition detector) that I can install on this setup :confused:
Old Aug 10, 2001 | 01:18 AM
cmillard's Avatar
cmillard
Default Re: Knock Detector (clearrun)
You can use a J & S knock sensor. Runs close to $500 (ouch), but it may be what you're looking for. You can search on http://www.google.com to find several links and comments.
Hope this helps,
Christian
Old Aug 10, 2001 | 03:13 AM
bill mcdonald's Avatar
bill mcdonald
I have a knock detector in my '90. it has a 7 light LED bar, this only allows me to see how much detoanation I am getting, it does not control timing.
It is made by MSD. It also has a sensitivity adjustment, and a volume control to a beeper. I think it runs about ~150.00.
I did some mods to move the lights from the bulky box, into the dash.
Old Aug 10, 2001 | 09:36 AM
Aaron's 87's Avatar
Aaron's 87
There's a lot of talk on the DIY list about connecting a KS to headphones and listening to your engine. That'd be cool.
Old Aug 11, 2001 | 08:32 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: Knock Detector (Aaron's 87)
Aaron
u can turn off the stereo and listen to the engine. that's cool too! :rolleyes:
Old Aug 11, 2001 | 10:29 AM
El Mago's Avatar
El Mago
I actually bought the J & S system but never installed it. This was around 08/97 after reading an article either on Car Craft or Hot Rod mag. Paid something like $600. It does have individual cylinder knock control and you can set it up to run from a V8 to a rotary engine.
I guess now a days what it does is already included in the F.I. computers, to me it was a way of knowing if my spark curve on the edelbrock f.i. was too advanced...
anyways, I lightened up, and left it on the shelf, will probably take out the whole FI and go back to carb & manifold (Rochester performer rpm & Weiand Team G).
If you do want to have an idea of how it works I could try finding the instructions and scan them for you.
Gary
Old Aug 11, 2001 | 10:52 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: Knock Detector (drives61)
Aaron
You can hear a lot more through the piezo knock sensor.
To Knock Detector
