Keith Black Hypereutectic Pistons
Old Feb 6, 2006 | 03:56 PM
loiq's Avatar
loiq
Default Keith Black Hypereutectic Pistons
Are they junk?
Old Feb 6, 2006 | 05:08 PM
Deakins's Avatar
Deakins
I have not had any problems with them in a 600 hp 355 that turns 7500 RPM.
Old Feb 6, 2006 | 05:21 PM
Rusted40's Avatar
Rusted40
MAKE SURE you check the ring gaps
follow piston manufacturer reccomendations on this
I have seen the top ring land beaten out of these from
too little ring gap clearance
Old Feb 6, 2006 | 05:58 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
Been there, done that. Had the parts in my oil pan to prove it.
Old Feb 6, 2006 | 06:16 PM
BLOCKMAN's Avatar
BLOCKMAN
At our engine shop we don't feel comfortable using hypers as over the last few years we have had more calls and emails on broken hypers then all the years dealing with forged pistons.
No matter how your look at it its still a cast piston.
Old Feb 7, 2006 | 03:45 PM
gkull's Avatar
gkull
Originally Posted by loiq
Are they junk?
Mine worked fine on a B&B 355 ci until I went with big heads and a roller cam. According to KB they have sustained FPM limitations. Mine failed in 15 minutes or so of continues 6000+ rpm with only a 3.48 stroke.
I'd run them over 7000 on many occasions like drag racing. Open road racing at constant high rpm and they melted the skirts and ring lands. clouds of blue smoke and it sounded like rod knock.
They have some good points like tight cylinder to wall clearance. They would be fine in mildly built up motors.
Old Feb 7, 2006 | 06:25 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Like stated above good for mild buildups and occasional blips to 6500RPM but for a serious motor ( racing applications, sustained high RPM ) go forged. And like stated above you cannot gap the rings the same as other hyper pistons, has something to do with the material they are made of
Old Feb 8, 2006 | 01:37 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've been running them for over 20K miles in my current engine with no problem. Proper ring gap is indeed critical though.
To Keith Black Hypereutectic Pistons
