Valve Clearance?
Old Feb 24, 2006 | 12:56 AM
Tumarr's Avatar
Tumarr
Default Valve Clearance?
I am putting together a 383 and had a question about clearance for the valves. I am considering using a mechanical roller cam that has about .580-.6 lift. I am almost positive that there will be issues with the valves hitting the pistions due to the unconventional layout of the valves in my heads. My heads are Trickflow twisted wedges. What I wish to know is, is there a tool I can use to grind proper valve reliefs into my pistions so that I will have enough clearance? such as a cutting bit the same size as the valve and bolt the head on and lower it onto the piston to grind the reliefs. maybe I can just sharpen a valve and use that as my cutter. Is this a smart way to do this?
Old Feb 24, 2006 | 08:53 AM
BLOCKMAN's Avatar
BLOCKMAN
We have always used a piston vise and a Bridgeport and a flycutter to cut the reliefs in the pistons and on some pistons its not a good idea to cut reliefs to deep as it may get thin in that area a cause the tops of the pistons to crack as we have seen this happen in the past.
It would be a good idea and call the piston manufacturer to see how they can be cut and a engine shop that does this type of work would be your best bet on doing a good job.
Old Feb 28, 2006 | 06:58 AM
zo6vetteman2003's Avatar
zo6vetteman2003
If you didn't purchase pistons with the reliefs already cast in, here is an alternative method to check your P/V clearence, and to see if you need reliefs cut in.
Put about a half inch dollup of modling clay on the intake and exhaust valve head. Bolt the cylinder head on with the old gasket (if you have one) and 4 head bolts. Turn the crank over by hand through one revolution to cycle the valvetrain. You must use a solid lifter, or a checking valvespring, so the lifter does not collapse and give you a false reading. Remove the head and measure the depth of the clay by plunging a micrometer through the thinnest portion. It should be more than .120" on the exhaust valve and .090" on the intake valve, or you will need reliefs cut into the pistons. Do not use playdoh or it will give you a false reading due to its memory.
Old Feb 28, 2006 | 06:49 PM
glen242's Avatar
glen242
Way back before electricity was invented , we used to take a valve that we wanted to use, and put an edge on the face. We then put it in the head, bolted it down, and used a drill to spin it and cut a relief in the piston. Check your HOT ROD mags from the '50s.
It worked back then, should work now.
Old Feb 28, 2006 | 06:55 PM
zo6vetteman2003
The valve was used as the drill bit you are saying? If so very cool. So you mean a valve exactly like the one you are going to use.
Old Mar 1, 2006 | 09:07 PM
glen242's Avatar
glen242
Yes, a valve exactly like you were going to use. As I said, this was in the dark ages, but should still work today.
Old Mar 1, 2006 | 09:31 PM
BLOCKMAN's Avatar
BLOCKMAN
When we cut the valve pockets in pistons we clearance .050 away from the edge of the valve so there will be no interfearance and cutting a valve pocket with the same size valve your going to use is not going to give you the proper clearance on the edge of the valve.
HMMMMMM
To Valve Clearance?
