406 Internal vs External balance??
Old Jun 18, 2006 | 09:26 AM
Brett Richmond's Avatar
Brett Richmond
Default 406 Internal vs External balance??
I am about to buy a 406 from a friend that does not have the crank in yet(on order), the motor will go in an 89. Should this motor be balanced in or out?? I need to find out so I can have a different crank installed before hand.
Old Jun 18, 2006 | 11:05 AM
CFI-EFI's Avatar
CFI-EFI
The 406 is a 400 engine that has been bored .030" over, and was originally externally balanced. Most engines that get a simple bore job, don't get the crankshaft replaced. If you want an internally balanced engine you can have heavy metal added to your crank or buy one with it installed.
RACE ON!!!
79VetteMike's Avatar
79VetteMike
I always internal balance. Your engine will run smoother and it will rev higher. It should also take care of your engine parts better, because the balance is on the inside near the rotating parts and not at the end of the crank where it is being stressed.
Old Jun 18, 2006 | 06:55 PM
LD85's Avatar
LD85
Do yourself a huge favor, and have it internally balanced now, or buy an internally balanced crank
I just went thru 3 years of screwing around with this stupid external balance crap,
you have a limited choice of flywheels, dimensional stack up tolerance crap when using a balance plate, I beg you to have it internally balanced,
Old Jun 23, 2006 | 05:00 PM
Edzred72's Avatar
Edzred72
Originally Posted by LD85
Do yourself a huge favor, and have it internally balanced now, or buy an internally balanced crank:
Do yourself a favor and purchase an internally ballanced crank, and have the entire rotating assembly (pistons/rods/crank) ballanced at the same time. Not expensive and WELL worth the $$$
Eddie
Old Jul 25, 2006 | 09:06 AM
loiq's Avatar
loiq
Good info.
Old Jul 25, 2006 | 09:31 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine is externally balanced and revs smooth as a babies azz to 6500 RPM. Scat now sell a internally balanced nodular iron 9000 series crank for a 406ci
Old Sep 11, 2006 | 08:43 PM
NitrousSam's Avatar
NitrousSam
Internally balanced is certainly better especially if you have plans of spinning your engine down the road. Also, internally balanced utilizes a smaller harmonic balancer. Take a look at the BH&J balancer if you internally balance. They look a little like a stock unit but they work awesome. My 406 in my pro street truck runs 8300 rpm over and over for years without an issue and it's internally balanced.
Old Sep 11, 2006 | 11:51 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
There's no reason on earth to not internally balance when building from scratch. My 388 uses all lightweight stuff, the small ATI damper, neutral flexplate, etc. and is one smooth SOB.
To 406 Internal vs External balance??
