Input needed on which way to go..
Old Sep 9, 2001 | 04:29 PM
BiZ's Avatar
BiZ
Default Input needed on which way to go..
I was at a local performace shop getting a price on a motor. I am looking at a 355 or a 383. Using the dyno software he had we came up with these #'s.
355--405hp--450tq
383--420hp--480tq
Now the price is where things get interesting. The 355 installed is going to cost ~1850.00. The 383 installed is going to cost ~2850.00. The only difference on the two motors is the displacement. I am supplying the heads and intake.
So you tell me, is the extra 15 hp and 30 ft/lb worth the extra grand? Will the 383 be any more reliable or last longer?
Old Sep 9, 2001 | 09:32 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Input needed on which way to go.. (BiZ)
What may I ask are you getting for that kind of money?
Something doesn't sound right.
Old Sep 9, 2001 | 09:56 PM
BiZ's Avatar
BiZ
Default Re: Input needed on which way to go.. (mackeyred96)
He is building the shortblock. I bring him my heads and intake. He assembles the new motor. I drop my car off, he does the swap.
Old Sep 9, 2001 | 10:39 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
If he can guarantee all those numbers...take him to lunch either way:yesnod:
Old Sep 9, 2001 | 10:53 PM
BiZ's Avatar
BiZ
Default Re: Input needed on which way to go.. (yellow 72)
I'm sure the #'s won't be exact. How accurate can the software be? But if I can get close to that I will be happy.
Old Sep 10, 2001 | 09:40 AM
Aaron's 87's Avatar
Aaron's 87
What kind of parts will he use? 383 shouldn't cost a grand more.
Old Sep 10, 2001 | 07:47 PM
BiZ's Avatar
BiZ
Default Re: Input needed on which way to go.. (Aaron's 87)
I believe that he already has a 355 ready to go. The 383 would require more parts ordering and machine work to be done. I think he is tryin to steer me into the 355. Which I don't mind. It seemed to make nice #'s. Does the price sound about right for the 355? It is pretty much 925 for the shortblock and 925 to assemble and install.
Old Sep 12, 2001 | 03:36 PM
norvalwilhelm's Avatar
norvalwilhelm
Bigger is better in this case. Why not build a 400. It shouldn't cost more then the 355 and the extra 50 cubic inches should show in torque and horsepower. I favor big blocks so i really don't know what I am talking about. I do have a big block and nitrous 355 and there is not comparison between the two.
Norval
Old Sep 12, 2001 | 07:37 PM
BiZ's Avatar
BiZ
Default Re: Input needed on which way to go.. (norvalwilhelm)
Are either of those cars your daily driver? Mine was, is, and will continue to be driven every day. I just want something that is going to be extremely reliable and deliver enough power to put a :D on anyone's face who rides in it.
I know that no matter how fast I make it there will always be someone faster. I want a car that is capable of running solid 12's. Then be tame enough to drive with my 8 yr old nephew in the car.
Old Sep 12, 2001 | 09:55 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
If you can afford it, why not go bigger? You can only go as fast as your wallet will let you:D
30ft/lbs is enough to feel a difference and if you don't go bigger now, you'll regret it later. Trust me:D
Old Sep 12, 2001 | 11:21 PM
buddy11's Avatar
buddy11
your only going to pick up 20 to 30 hp with a .0030 over and a balance job ( w/355 )... unless you go high compression or light wieght parts, and for $950 you most likely not getting either...
Old Sep 13, 2001 | 08:27 PM
AKS Racing's Avatar
AKS Racing
I would be very careful of what you are getting for that kind of money. There should be little difference in the cost of parts (355 vs 383) when using quality parts. I would guess that a 383 with good quality forged components should run in the $3500 range for just the short block.
Best of Luck,
Aaron
To Input needed on which way to go..
