timing chain or gear drive?
Old Aug 26, 2006 | 10:08 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default timing chain or gear drive?
what do you guys think? obviously, application is an important consideration so here's the deal:
the car will be basic street rod stuff. not planning on doing (much) more track days and i'm considering running a mechanical cam. it'll definately be more healthy than stock. i'm not worried about the noise but i probably will be getting the quieter one anyway.
after disassembling the blown motor, i found that the cam sprocket had about half the teeth missing. my engineer guru friend tells me that's be cause i over rev the motor. didn't really even think that was possible since it had stock heads with the valve rotators and everything so i didn't think i'd be able to get that kind of RPM out of it.
anyway, this motor will be fairly stout compared to stock and as such, i may very well take it to 6500 from time to time.
Old Aug 27, 2006 | 08:14 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
6500 is no big deal on a well built engine. I'd get a good Cloyes DR set-up and forget it. There's nothing wrong with a gear drive but I find the noise atrocious on a street car. I realize some like that sound, but I don't. The gear drive is overkill and needless expense for your needs.
Old Aug 28, 2006 | 12:29 AM
Ironcross's Avatar
Ironcross
427 L88`s and 454 LS7`s are chain and gears at well over 500+ honest HP
Old Aug 28, 2006 | 04:46 PM
IronJen's Avatar
IronJen
Abby Normal
guys, i'll probably go with the chain. however, the price difference between a *good* chain and the gear is only about $30 so i just thought i might as well step up. i know both have their drawbacks but maybe i'll find a few more horsepower for the extra couple bucks.
Old Aug 28, 2006 | 07:35 PM
540 RAT's Avatar
540 RAT
A good true roller double row chain doesn't really have any drawbacks. You won't see any hp increase with a gear drive, in fact just the opposite, because of crankshaft vibration harmonics that will be transmitted to the valve train. Also on a kickback, the gear drive is so solid that it has been known to cause damage that would not occur with a chain that can absorb some of the shock. Do yourself a favor and go with a good chain, that will be stepping up.
Old Aug 28, 2006 | 11:39 PM
IronJen's Avatar
IronJen
Abby Normal
o.k. guys, i'm sold. the cloyes i'm going to order has billet cam and crank sprockets so i feel more comfortable about it than that cheap set with the cast iron cam sprocket (or, as i now call it, the explode-o-matic sprocket).
To timing chain or gear drive?
