not your average cam question
Old Jan 3, 2007 | 07:07 PM
Rdavis's Avatar
Rdavis
Default not your average cam question
Does anyone know if you can use a stepped-nose hyd roller (factory type) in a one-peice seal block, using retro fit lifters & a thrust button.
The reason I ask is that I have such a cam leftover from my LT1 Firebird days. Any input will be apreciated.
Old Jan 4, 2007 | 10:25 AM
C4Techie's Avatar
C4Techie
The stepped-nose (factory type) hyd roller cam was only used one piece seal blocks.
Old Jan 4, 2007 | 12:48 PM
Rdavis's Avatar
Rdavis
Yes, I understand that, but could it be used in a 2pc seal block by using a thrust button rather than the plate that is used on the factory roller blocks.
Old Jan 13, 2007 | 01:13 AM
Deakins's Avatar
Deakins
I don't see a reason that it wouldn't work. I would verify that all the critical measurements are correct and then set the end play like any roller cam with the stop.
Old Jan 14, 2007 | 05:46 AM
SteveG75's Avatar
SteveG75
I believe the stepped cam uses a different timing chain gear with a smaller bolt pattern. As such, you won't have room for the thrust button.
Old Feb 4, 2007 | 12:30 PM
Snakeskinner's Avatar
Snakeskinner
Yes-LPE can fix you up
To not your average cam question
