New pistons, balancing question
Old Jan 15, 2007 | 04:46 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default New pistons, balancing question
I am replacing the pistons on an existing internally balanced motor. I am looking to avoid rebalancing the assy...
Can this be done if the new pistons are weight matched to the old? Will this retain the balance?
Old Jan 15, 2007 | 09:05 PM
danno85's Avatar
danno85
Absolutely!
Old Jan 20, 2007 | 10:22 AM
Mike_B's Avatar
Mike_B
If the new pistons, pins, circlips (if any), and rings are within a gram or two of the originals, you will be fine.
To New pistons, balancing question
