Yup...I found my really, really stupid mistake...
Old Oct 8, 2001 | 09:30 PM
81ZZ4's Avatar
81ZZ4
Default Yup...I found my really, really stupid mistake...
OK, when I put on my new top end on the ZZ4 block it was faster but questionable as to "bang for the buck".
Well, I did a big stupid mistake...
When I placed the new distributor in the block along with my new AFR 190's, Edelbrock RPM intake and all the other expensive stuff I timed it by setting the Distributor at 12 degrees @ about 800 rpm's.
It was faster for sure but after checking and re-checking I threw the timing light on it to see where my advance went up to as I brought up the rpm's.
It would only advance to 24 degrees.
The great part is I never knew I was supposed to adjust the distributor till it went to a full 36 degrees while I brought of the rpm's.
This thing is now an out-of-control animal :crazy:
It's just sooooo fast I can't believe it.
I drove it for hours over the past few days.
Finally it's a real American made rocket :flag
[Modified by 81ZZ4, 7:31 PM 10/8/2001]
[Modified by 81ZZ4, 7:32 PM 10/8/2001]
Old Oct 9, 2001 | 09:51 PM
71roadster's Avatar
71roadster
Default Re: Yup...I found my really, really stupid mistake... (81ZZ4)
and this is after you were so happy with all that carb tuning?
Glad to hear it, I want to go the same route!
Old Oct 10, 2001 | 03:42 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Default Re: Yup...I found my really, really stupid mistake... (71roadster)
Are you saying that you timed the new engine with the EST wire still connected? If this is the case then the engine would have been way off on timing originally.
Cory
Old Oct 10, 2001 | 10:03 PM
81ZZ4's Avatar
81ZZ4
Default Re: Yup...I found my really, really stupid mistake... (CHarris85Vette)
I was impressed with the engine after all the work when I got the power valve deal under control. It made a huge difference.
I was playing with my new custom bike all summer and the Vette really sat after the power valve changes.
Now it's geting a bit colder so I started playing with the Vette agian.
I spoke with my friend that did the distributor curve and I assumed I set the timing as usual. Go the the normal idle rpm's and tweak the distributor to 10 or 12 degrees...
He informed me not to pay attention to the typical timing routine and leave the light on it while I revved it to 2,600 rpms and then tweak the dist. to bring full advance to 36 degrees.
WOW...this thing hauls major butt. I have sticky Eagle GT II's on it and now it will burn em right off the rims. No Joke. It's killer fast :yesnod:
Second gear is out sideways if I'm not careful.
I gotta hit the dyno again to see what it's actually doing.
[Modified by 81ZZ4, 8:07 PM 10/10/2001]
Old Oct 10, 2001 | 10:05 PM
81ZZ4's Avatar
81ZZ4
Whats an EST Wire?
Old Oct 11, 2001 | 02:34 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Whats an EST Wire?
EST is for computer controlled cars.Electronic Spark timing or something...
they prob. thought you had a EFI car or TPI.
Old Oct 11, 2001 | 08:07 AM
81ZZ4's Avatar
81ZZ4
Default Re: Yup...I found my really, really stupid mistake... (Bill's86Coupe)
OK, thanks.
Nope, I disconnected the computer... :chevy
Old Oct 15, 2001 | 08:40 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Can one of you explain timing real quick to me? Not to sure of what im thinking
Old Oct 16, 2001 | 04:12 PM
81ZZ4's Avatar
81ZZ4
Default Re: Yup...I found my really, really stupid mistake... (vettes rule)
in simple terms its how many degrees of a 360 degree circle of the crank stroke that the spark plug fires on the pistons way up to top dead center of the compresson stroke.
Hows that sound :D
Old Oct 18, 2001 | 10:59 PM
QuickVet's Avatar
QuickVet
glad to see your happy with your new setup. hope to see you at englishtown in a month. check out the corvettechallenge web site. http://www.corvettechallenge.50megs.com
Old Oct 19, 2001 | 04:00 PM
white 91 roadster's Avatar
white 91 roadster
:nono: :nono: :nono: :nono:
Old Oct 31, 2001 | 02:43 PM
81ZZ4's Avatar
81ZZ4
Default Re: Yup...I found my really, really stupid mistake... (white 91 roadster)
Sheeesh,
my close friend just purchased a 2001 Ram Air Trans Am.
I blasted the my Vette while I was in front of him. I have yet to put in the beefy special U-Joint caps I had made up for the extra horse. So I hit second gear easy...let off at redline, pause for just a touch...shift to second and then hit the gas again. We both have Nextel radios..
he yelled over the radio...I cant even try to keep up & how did you get 3 feet of posi when you hit second!
Isn't life Beautiful :yesnod: :lol: :yesnod:
To Yup...I found my really, really stupid mistake...
