Mod guys, what can I expect?
Old Apr 10, 2007 | 02:50 AM
AZC4Guy's Avatar
AZC4Guy
Default Mod guys, what can I expect?
Hello all. In a couple of weeks I'm going to hit the dyno and I really don't have a good idea of what to expect. I'm going to list the relevent mods and I'm hoping some of you will give your opinion. Thanks in advance for your learned input.
383, Edelbrock RPM Performer intake, Holley 650 DP Carb, Dart Pro1 Heads w/ 200cc intake runners, 1.6 RR's. Hooker long tubes, no cats, dual exhaust, 700R4 tranny built up by Pete K, .373 gears in a dana 44.
Thanks again,
Steve
Old Apr 11, 2007 | 12:47 PM
Deakins's Avatar
Deakins
Without cam specs we can not give you a good estimate. That said, we see a lot of Dart Pro 1's in the 500"s at the crank with good cams and some RPM. What are the specs on the cam you are running?
Old Apr 11, 2007 | 01:21 PM
AZC4Guy's Avatar
AZC4Guy
I meant to put the cam specs in..oops. Here's the numbers w/ 1.5 rr's.
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 280
Advertised Duration: 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.477 int./0.480 exh. lift
Lobe Separation (degrees): 110
Grind Number: CS XE268H-10
Thanks Deakins.
Old Apr 11, 2007 | 05:34 PM
Deakins's Avatar
Deakins
That cams a bit smaller than what we normally see but looks to be a good fit with the package. It will be very street friendly and I would be looking for somewhere around 450-475 at the crank depending on the compression. I don't think you will get the power up there high enough to really make big hp numbers on this 383 but it may surprise me! It's happened before so be sure to let me know what it cranks out!
Old Apr 12, 2007 | 10:43 PM
AZC4Guy's Avatar
AZC4Guy
I'd be happy w/ the numbers you listed Deakins. I appreciate your thoughts. i'll post the number when I get them back.
Thanks again!
Old May 8, 2007 | 07:57 PM
86VX1's Avatar
86VX1
what's up azc4guy, i would be very interested in your numbers as well. i have the same cam in my vet right now. with the exception of the rest of the engine. i have a 400, fast burn heads, and a mini.
at what rpm do you shift at right now? i tach out at 6500, which might be a tad on the high side for this cam.
Old May 10, 2007 | 08:09 PM
Taijutsu's Avatar
Taijutsu
Here's my SWAG 310 rwhp 325 rwtq
Ricisan
Old May 24, 2007 | 02:39 AM
USAsOnlyWay's Avatar
USAsOnlyWay
To Mod guys, what can I expect?
