383 Rod Bolt Clearance
Old Apr 28, 2007 | 07:44 PM
LTxDave's Avatar
LTxDave
Default 383 Rod Bolt Clearance
I am currently beginning the assembly of my 383. This is the first stroker SBC I have built and I have run into a question. I had the block clearanced by the machine shop. I put #1 and #2 pistons in and rotated the block to find VERY little clearance on the #2 rod bolt. I thought I was imagining things so I checked the clearance with a set of gauges and it is less than 0.006" (that was the smallest one I had). That seems REALLY tight to me. Am I being paranoid or is it realistic to believe the block may expand enough to cause a clearance problem at operating temperatures. The #1 rod bolt seems to have much more clearance. What is the minimum clearance recommended?
Old Apr 28, 2007 | 10:46 PM
big_G's Avatar
big_G
I believe .030 is enough, some run .060. I run .030 on my carbed ProCharged (D1SC) 383. When you get it together, let's compare notes!
Old Apr 28, 2007 | 10:56 PM
LTxDave's Avatar
LTxDave
Well, looks like the one I was concerned about has zero clearance when rotated counterclockwise. The others that I checked have at least 0.015" clearance. I still need to check 7 and 8 and then clearance #2.
Sounds like a nice build you have big_G. What numbers are you putting down?
Old Apr 29, 2007 | 11:06 AM
CFI-EFI's Avatar
CFI-EFI
The number I live by is .050". That is for both the block and the camshaft. Bolt clearance can vary widely, depending on the rods being used.
RACE ON!!!
Old Apr 29, 2007 | 05:29 PM
big_G's Avatar
big_G
No numbers yet, still dealing with fuel pump issues. Feels very strong so far, not going to beat it too hard until I can set my A/F ratio on the dyno.
To 383 Rod Bolt Clearance
