Hows this cam
Old Oct 20, 2001 | 12:22 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Hows this cam
Wondering what yall thought of this cam. My dad and mechanic got it for my 91.
[Modified by vettes rule, 11:24 AM 10/20/2001]
Old Oct 20, 2001 | 07:33 PM
QuickVet's Avatar
QuickVet
Default Re: Hows this cam (vettes rule)
to small! is that going in your zz4?
Old Oct 20, 2001 | 09:54 PM
your drinking buddy
Cruise-In V Veteran
Its already in my ZZ4. My dad and the engine builder talked and picked this cam, since im only 16. What top HP would this make? Whats its good points and bad points? When will the cam start to screw up with the idle?
Old Oct 22, 2001 | 12:06 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
You certainly won't have a problem passing emissions. Hard to guess horsepower just based on cam specs. I would guess it would be close to stock though.
Old Oct 22, 2001 | 04:45 PM
LT401Vette's Avatar
LT401Vette
The intake has the same lift as a stock LT1 cam :rolleyes:
Old Oct 22, 2001 | 05:27 PM
QuickVet's Avatar
QuickVet
Default Re: Hows this cam (LT401Vette)
if i were you, i would put some 1.6 roller tip rockers on those heads to beef up the cam a little.
Old Oct 22, 2001 | 06:08 PM
gkull's Avatar
gkull
Very wimpy as far as cams go. But i don't know at what point TPI without porting shuts down the motor anyway.
I don't let my 16 year daughter drive my vette without me in it. So maybe I should put in the same cam and it would be fine.
Old Oct 22, 2001 | 06:20 PM
your drinking buddy
Cruise-In V Veteran
Default Re: Hows this cam (gkull)
The heads take me up to around 10.5:1 CR, and whatever rockers they put on wouldnt fit under the stock valve covers.
So this cam is pretty weak? Thought so after I opened it up some. About how much does it cost for a new cam installed?
TPI usually dies at around 5K, so I want to put on a Super ram when im going to college, with a new cam.
Also, wanna post pics of your daughter? :lol:
Old Oct 22, 2001 | 08:50 PM
QuickVet's Avatar
QuickVet
[Modified by Vetteboy, 7:51 PM 10/22/2001]
Old Oct 24, 2001 | 10:12 PM
your drinking buddy
Cruise-In V Veteran
Whats a much bigger cam for a super ram or mini ram ZZ4 and 3.54 gears, that is still streetable? Any idea on how much it would cost to have it installed?
Old Oct 25, 2001 | 09:00 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VII Veteran
Thats a pretty weak cam. You could do alot better.
Old Oct 28, 2001 | 10:10 PM
Corey_68's Avatar
Corey_68
Default Re: Hows this cam (mackeyred96)
With the Super Ram, I would go withe the 219/219 cam. .525/.525 lift with 1.5 rockers and .560/.560 with 1.6. It was BUILT for the SR.
To Hows this cam
