LS-6 w/ Vortech blower streetable?
Old Jun 13, 2007 | 05:07 PM
crewguy's Avatar
crewguy
2nd Gear
Default LS-6 w/ Vortech blower streetable?
Posting for a friend........
He just had his 66 Vette rebuilt using an LS-6 crate motor and trans. The only mod to the motor was the addition of a Ligenfelter F.I. intake. Everything else is stock with the addition of a tuned chip. He is kicking around the idea of adding a Vortech blower. What will this do to the streetability of the car? The blower will be professionally installed and a new chip will be burned in for the new combo.
Old Jun 14, 2007 | 01:25 PM
big_G's Avatar
big_G
A little late in the game to consider a blower, IMO. The compression ratio is high. An inter-cooler is mandatory, and even then the boost will need to be 6 lbs. or less. When I built my engine, I set the c/r at 8.3, to allow up to 16 lbs. boost on pump gas. Look at the pic.below, it's a '68 'Vette, but the space constraints are the same. G/L
Old Jun 15, 2007 | 07:26 PM
crewguy's Avatar
crewguy
2nd Gear
Thanks for the reply. The intercooler is needed because of the compression ratio of a stock LS-6? What would be the HP increase? 100HP? Right now the motor has a slight problem with the chip (lag). He just had some type of mod to the brakes that use the power steering pump as a booster. I am assuming that adding the blower would necisitate modding the accessories on the front of the motor. My opinion is that he doesn't need the blower. Anyway, thanks for the imput.
Current state of the car
Old Aug 6, 2007 | 08:58 PM
KNEVER's Avatar
KNEVER
Just my 2 cents but some port work and a cam upgrade would be cheaper and make more power. The car looks sweet by the way.
Old Aug 11, 2007 | 11:42 AM
TLewis4095's Avatar
TLewis4095
Big G is correct, the LS6 is a high compression engine, you would need to swap some large chamber heads (LQ9 trk heads work good) on it to lower the CR to mid 8's. I am confused though, the LS6/LS1/LS2 all run with a PCM/ECM. No chip.....even the after market engine controll systems such as the FAST use programing via a software suite. The old LT1/LT4 C4 cars used a PROM chip.....even in a retrofit application you would use a programmable controller.
FI on a high compression engine is asking for detonation & catastrophic failure.....even with an intercooler uless the boost is limited as stated above.
To LS-6 w/ Vortech blower streetable?
