BB Head Volume Unknown
Old Jun 25, 2007 | 01:04 PM
Dbabich11's Avatar
Dbabich11
4th Gear
Default BB Head Volume Unknown
I need help in defineing my head volume (cc) to select the correct pistons for a LATE 69 BB rebuild at +.030. I want to stay close to the
original compression ratio 10.25:1. New pistons with domes are rated with the head volume for compression. My heads are #3964290 which is a 1970 454 head but was used on late 427's (same bore). Is there a place to find this info?? Dbabich11
Old Jun 25, 2007 | 05:05 PM
knight37128's Avatar
knight37128
3964290....69-70...oval..CLOSED..396, 402, 427, 454, 101cc chamber
Large or small hex spark
plugs used
http://www.mortec.com/bbc.htm
Old Jun 25, 2007 | 09:26 PM
Dbabich11's Avatar
Dbabich11
4th Gear
Default Thanks for the Reply
Thank You very much for the info. We are measuring the old (original) domes, now avaialble are .140 dome and .266 dome.
Thanks again for your input. Dbabich11
To BB Head Volume Unknown
