Could I get a Dyno?
Old Oct 30, 2001 | 07:02 PM
Clink69's Avatar
Clink69
Default Could I get a Dyno calculation?
Can anyone run my 383 buildup for HP and TQ?
Its a .030 over 350 block with 400 crank
Pistons - JE SRP forged Alum
CR - 10:1
Canfield 23-500-65 195cc intake port volume, 1.60 / 2.055 valves, chamber 65 cc, 1205
Felpro
Flow is:
lift intake ext
.1--72--53
.2--145--107
.3--201--143
.4--247--175
.5--258--190
.6--259--200
.7--259--203
Cam - comp cams duration 274/286, 230/236 @.050, lift 519/522, LSA = 110
rods - forged 4340 6 "
crank - Eagle forged steel ARP bolts
Intake - Edel performer
Carb - 750 cfm
Ignition - MSD 6AL + MSD tach drive distributor
Exhaust - hooker 1 5/8 " headers to 4 inch sidepipes with 2" glasspack
Thanx in advance: :flag
[Modified by Clink69, 5:56 PM 10/30/2001]
[Modified by Clink69, 7:09 PM 10/30/2001]
[Modified by Clink69, 8:19 PM 10/31/2001]
Old Oct 30, 2001 | 07:26 PM
QuickVet's Avatar
QuickVet
Default Re: Could I get a Dyno? (Clink69)
what is the lobe center angle?
Old Oct 30, 2001 | 10:45 PM
Clink69's Avatar
Clink69
Default Re: Could I get a Dyno? (Vetteboy)
Lobe Center is 110 degrees. :flag
Old Oct 30, 2001 | 10:58 PM
QuickVet's Avatar
QuickVet
should put you somewhere between 400-450 HP. the dyno program is never exactly correct. you should make over 400 HP with over 400 TQ.
To Could I get a Dyno?
