BB SB What's the Difference?
Old Nov 16, 2001 | 06:05 PM
Nyvette's Avatar
Nyvette
Default BB SB What's the Difference?
I have seen 427 cu in. big blocks and 427 cu in. small blocks, what is the difference?
Old Nov 16, 2001 | 06:24 PM
71coupe's Avatar
71coupe
Default Re: BB SB What's the Difference? (Nyvette)
about 200 pounds :cheers:
The small block 427's you see here use an aftermarket block based on a small block Chevy. Most small block parts will fit, though the small block 427's here use very little factory GM parts.
The biggest small block chevy built was a 400.
The big block 427 is physically larger than the small block and it was produced from GM . Factory Big block displacements were/are: 396, 402, 427, 454, 502 all of these use the same block with a few differences.
[Modified by 71coupe, 3:34 PM 11/16/2001]
Old Nov 16, 2001 | 08:26 PM
Nyvette's Avatar
Nyvette
Thanks! :cheers:
Old Nov 16, 2001 | 10:32 PM
No Go's Avatar
No Go
Default Re: BB SB What's the Difference? (71coupe)
Don't forget the 366 big block chevy! AACK!
Old Nov 16, 2001 | 11:48 PM
67HEAVEN's Avatar
67HEAVEN
Default Re: BB SB What's the Difference? (No Go)
There's always one trucker in the crowd! :jester
To BB SB What's the Difference?
