zz383 mechanical fuel pump
Old Oct 31, 2007 | 08:49 PM
yellow94coupe's Avatar
yellow94coupe
Default zz383 mechanical fuel pump
I've got an Edelbrock fuel pump from my old engine (2 piece rear seal block made in 1974) that I'd like to reuse if possible. My mechanic says the GM Performance Parts ZZ383 will not work with a mechanical fuel pump yet it looks like it has the stuff for one but it is just covered with a plate. I read somewhere that you just need a different pump rod and you are good to go. Is this right? Would anyone know a manufacturer and part number of whatever it is I'm missing?
Thanks!
Old Nov 1, 2007 | 09:50 AM
knight37128's Avatar
knight37128
If there is no lobe on the camshaft the fuel pump will not work. That is the question.
Does the cam have a fuel pump lobe?
Old Nov 1, 2007 | 03:49 PM
yellow94coupe
Yep, the cam is compatible with a mechanical pump. It turns out they thought the block didn't have the pump rod hole so they recommended an electric pump. I had them double check and they said my old pump would indeed work.
Old Jan 23, 2008 | 04:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
If it has a roller cam with FP eccentric use a pushrod with the bronze tip.
To zz383 mechanical fuel pump
