383, 434 questions
Old Feb 7, 2008 | 06:18 PM
arh's Avatar
arh
Default 383, 434 questions
i currently have a 383 with world sportsman II heads that has a mild cam(unknown grind) and is not very quick. the car is a 63 conv. with a 4 speed and 3.73 gears. my question is do i put in a solid roller and a set of afr heads on the 383 or build a 434 (i already have the block)and use my sportsman II heads. i am trying to stay within about a $3500 budget. which combo would make more power?
thanks,
adam
Old Feb 9, 2008 | 10:23 AM
gkull's Avatar
gkull
You need to maximize what you have with a good roller cam of around 236 intake. You also need something like a Weiand Stealth dual plane or their single plane. You need good headers and a free flowing dual exhaust system.
Then you can reuse all these parts if you ever decide to upgrade to a 400+ ci
Old Feb 9, 2008 | 10:51 AM
arh's Avatar
arh
Default world heads
the world heads are 10+ years old with very low miles. is it worth the money to upgrade with newer heads? it has a victor jr. intake.
Old Feb 9, 2008 | 10:59 AM
BLOCKMAN's Avatar
BLOCKMAN
We have seen some good results using the big runner Vortec Bowtie heads.
Old Feb 9, 2008 | 11:18 AM
gkull's Avatar
gkull
What is the max rpm you plan on spinning your motor? The SPII heads with a bigger cam and mid .500 lift can feed a 383 up to about 6000 rpm.
The VJ intake is a poor example. Without turtles installed and time on the flow bench it provides fuel separation........ It was intended for 4000-8000
Old Feb 9, 2008 | 06:19 PM
ironarms's Avatar
ironarms
St. Jude Donor '05-'08-'09
if you have side exhaust and go with the afr heads you will need custom headers as i have found that no one makes headers for the raised port heads and side exhaust, ( Stahl makes them custom)
To 383, 434 questions
