Thoughts On Engine Combination...
Old Dec 10, 2001 | 12:07 PM
bence13_33's Avatar
bence13_33
Default Thoughts On Engine Combination...
I was wondering if someone could punch these engine specs into Desktop Dyno for me, I was curious as to the net/gross HP & TQ. Any thoughts and/or opinions are always welcome :)
454 ; 2 Bolt Mains (+.060") = 467ci
Speed Pro Forged Pistons (10.5:1 CR w/ My Heads)
4340 Forged 6.135" (Stock Length) Rods
4" Stroke Cast Crank
"206" 96cc Closed Chambered Heads, 2.19/1.88 Valves, Intake & Exhaust Gasket Matched Port Job
Comp Cams 294S Solid Lifter Cam, 248 Duration @ .050", .595"/.595" Lift, 110 Lobe Seperation
Edelbrock Torker II Aluminum Single Plane Intake, Gasket Match Port Job
Holley 850cfm Double Pumper Carburetor
GM HEI Ignition
Hooker Header Side Pipes (Open Header Exhaust) 2" Primaries / 4" Collector
I'm just curious as to the effective RPM range of this engine, and what kind of numbers it will be pushing. Thanks!
Old Dec 10, 2001 | 10:56 PM
Flareside's Avatar
Flareside
Default Re: Thoughts On Engine Combination... (bence13_33)
Bence, can't do it without flow numbers for your heads :( Since you're talking about extensively modified stock heads with big valves, they could flow anything. Pick a stock head and I'll run it for you.
-Joe
Old Dec 11, 2001 | 12:26 AM
bence13_33's Avatar
bence13_33
Default Re: Thoughts On Engine Combination... (Flareside)
I really have no idea what heads to pick, I don't know what pair would be comparable to the pair that I have. I really need to get a book on Chevy heads....
Old Dec 11, 2001 | 01:27 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I'm traveling this week so I can't get you the exact issue, but years ago Hot Rod magazine built that exact combo with several other versions thrown in. I want to say it was around 1990-93 or so but I'm just guessing. It had a picture of a orange Super Bee on the cover along with the whole issue being devoted to Supercars.
Anyway they ran that basic 10.0 long block ( but pocket ported open chamber oval ports) and ran several different cams from hydraulic flat tapppets and several solid rollers. The ran the 294S and the 306S and played with retarding them etc plus some intake swapping. The ran Weiand, Holley and Dart intakes. It seems like the ultimate combo made 570-580 hp. It was the Dart with a 300* solid roller. The others were in the mid 500 range. Overall it's one of the best articles I ever saw with lots of good data on all the combos. Actual dyno tests will give lots of curves that are much better than DD program.
Hopefully some one can tell you exactly which one it was. if not I can get ti for you but it won't be until the weekend.
Jim
Old Dec 12, 2001 | 12:36 AM
ML67's Avatar
ML67
I have the same Comp roller cam used in the article for sale. Please e-mail me if interested.
BTW I'll echo Jim's sentiments -- that article was the best engine development article, with test results, ever published by Car Craft. Unfortunately I cannot locate the article or I would post it here.
Your combination will make very good power -- in the low 500 HP range depending upon final head flow figures. Open headers???
Take care,
Mark
Old Dec 13, 2001 | 10:19 PM
bence13_33's Avatar
bence13_33
Default Re: Thoughts On Engine Combination... (ML67)
Yea, I'll be running open headers (reverse flow mufflers are too restrictive) for the time being until I can scrape together $300 for the JCL Spiral Baffle Muffler Inserts :).
You have mail.
Old Dec 14, 2001 | 12:13 AM
Flareside's Avatar
Flareside
Come on Bence, running open headers on the street just ain't right. Resist the dark side! ;)
-Joe
To Thoughts On Engine Combination...
