Heddman Hedders
Old Mar 28, 2008 | 10:46 PM
BlackRocket's Avatar
BlackRocket
Default Heddman Hedders
I just took delivery of some Heddman Hedders from Summit that are designed for C-4 Vettes and found that the exhaust ports are round.
The exhaust ports on the heads are rectangular. Will this cause a large perfromance drop? This car is being built as a track only car to run around a track just for fun. I am adding true dual 3" exhaust, but if the port mismatch causes a huge depreciation in power I may have to upgrade to Hooker$.
Thanks!
Old Mar 29, 2008 | 12:17 PM
CFI-EFI's Avatar
CFI-EFI
Unless the header ports are smaller than the head ports, the shape mismatch provides an advantage unavailable by more closely matched ports. Any reversion, reverse pulses, in the exhaust system will be inhibited from entering the head as it travels back up toward the head, when it encounters the "brick wall" of the mismatch. The same is true of "D" shaped exhaust ports. A close match of shape between the head and the header is not only unnecessary it isn't even the best scenario. If the header ports are smaller than the head ports, THEN, you have a problem.
RACE ON!!!
Old Mar 29, 2008 | 12:29 PM
auctionman256's Avatar
auctionman256
i would send them back for the right one
Old Mar 29, 2008 | 02:55 PM
BlackRocket
Turns out that Heddman doesn't make a rectangular port header for the L-98. The Hookers all come with the smog tubes.
With that and since the ports aren't mismatched too much, I'll probably just install the Heddman's!
Old Mar 29, 2008 | 06:30 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
the hookers do not all come with smog tubes. try 2151's i believe
Old Mar 29, 2008 | 06:48 PM
BlackRocket
You're right about the Hookers!
Thanks!
Old Mar 30, 2008 | 11:44 AM
CFI-EFI's Avatar
CFI-EFI
Hooker 2149 = Smog fittings, ceramic coated.
Hooker 2151 = No Smog fittings, painted.
Hooker 2151-1 = No Smog fittings, ceramic coated.
The Hookers have 1 3/4" primary tubes. The Hedmans have 1 5/8" tubes. The smaller tubes will start to "work" at a lower rpm, and for the vast majority of SBCs won't sacrifice power on the upper end.
A small mismatch can be "adjusted" with a grinder, if the header is smaller than the head port. Once again, if the header is bigger than the head port, the mismatch is an advantage.
RACE ON!!!
Old Jul 16, 2008 | 09:39 PM
nate23's Avatar
nate23
I have those headers. The header port is larger than the exhaust port. You are good to go.
To Heddman Hedders
