LT1/4 timing chain slack
Old Apr 1, 2008 | 06:35 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default LT1/4 timing chain slack
In the middle of a elec water pump install and pulled the timing cover to remove the water pump drive. The current LT4 chain has roughly 30k on it. If I rotate the crank to pull the slack out of the timing chain on the pull side I have right at 1/2" of slack. About every SBC has some slack in it but I couldnt find a spec that specifies how much is too much. Does this seem excessive?
Old Apr 1, 2008 | 08:07 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Russ, when i did the electric pump on my LT-1 i did a regular (non LT-1, hyd roller) Cloyes double roller chain as i noticed the same thing you did
Old Apr 3, 2008 | 04:41 AM
1981Z06Vette's Avatar
1981Z06Vette
I used the same chain...much cheaper than the alternatives.
To LT1/4 timing chain slack
