timing chain set question ?
Old Dec 16, 2001 | 05:47 PM
ram82fire's Avatar
ram82fire
Default timing chain set question ?
Has anyone here used a cloyes [hex adjust model ] timing chain set ? What do you think based on actual use ?
Old Dec 17, 2001 | 04:54 AM
mountainmotor's Avatar
mountainmotor
Default Re: timing chain set question ? (ram82fire)
It is just a quicker way to degree the cam instead pounding the offset bushings in and out.Most cams today have 4-5 degrees of advance ground into them to make up for timing chain stretch later which can retard the cam 3 degrees or so.Unless you like to play,a regular Cloyes will do the job for you.
Old Dec 17, 2001 | 08:48 AM
ram82fire's Avatar
ram82fire
Default Re: timing chain set question ? (mountainmotor)
I have one here ,,,, I am a little leery of it,s ability to stay in time once adjusted . Looks like something more to give me grief down the road. I slept on it and I,m going to reorder and return this set today !!! Thanx for your time !!
GEO
Old Dec 26, 2001 | 09:13 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Just installed the CLoyes True double Roller the other day. It had the 3 keyways for advance/retard settings along with stock 0 setting. This unit is made very well and I would highly recommend it. Much better than the stock one I took off. I think it cost 79.00 from summit. :cheers:
Old Dec 26, 2001 | 09:26 AM
ram82fire's Avatar
ram82fire
Default Re: timing chain set question ? (ski_dwn_it)
Thanx for the comment ski ,,,,, I usually use the multiple keyway type,,,,, I returned hexadjust last week and installed a different setup !!!! Hello from eastern PA :seeya
Old Dec 26, 2001 | 03:00 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Ram,
No problem dude. Nice to see some other fellow P.A.ers here. At times I think we are overrun by these all year sun guys. Boy oh boy if they only knew what they were missing. :rolleyes: I keep repeating to myself: Warm sun, green grass. Help with the winter blues.
To timing chain set question ?
