Which Plug for Supercharged LT-1?
Old Dec 20, 2001 | 01:05 AM
EricVonHa's Avatar
EricVonHa
Default Which Plug for Supercharged LT-1?
I was running the Bosch +4's, but what is a more adequate plug and heat range for my supercharged LT-1?
Old Dec 20, 2001 | 12:22 PM
Red5's Avatar
Red5
Default Re: Which Plug for Supercharged LT-1? (EricVonHa)
I expect a LOT of people will disagree with my next statement. I have found the Split Fire plugs to work well with my L98 Ati Intercooled blown L98.
I am still using the stock chip and MAF and tend to run rich. I run the car rich because rich tends to be safe. I blow motors all the time. :rolleyes: And it gets rather expensive and time consuming. :cry
Old Dec 20, 2001 | 01:01 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Definately stay away from the Platinum plugs for any power added car. Personally, I use Autolites. I would recommend them or the NGK V-power plugs.
Old Dec 20, 2001 | 01:47 PM
EricVonHa's Avatar
EricVonHa
Guys, thanks for the replies on the plug deal... I shoulda worded it a little more clearly from the get go... what heat range of plug should be used. More heat, higher combustion temps... means?
Old Dec 20, 2001 | 02:19 PM
XTwinTurbo's Avatar
XTwinTurbo
I use to run NGK Tr55 (stock heat range) and the Vette ran good.
This year I tried going to NGK TR6 (one range colder). The Vette runs good after about 1200 rpm but occasionally I can feel a slight miss at idle. Don't know if it's the plugs or something else.
I would suggest you go with NGK TR55's in copper form (not platinum). These are the stock recommended range of plugs. If you are going to run serious boost, i.e. 9 psi or more than go to one colder step.
Old Dec 20, 2001 | 03:28 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Which Plug for Supercharged LT-1? (XTwinTurbo)
Stock range in the Autolite is a #106. I use a #103 for my Nitrous setup which I would recommend similar for a blower installation. Gap them at .035.
To Which Plug for Supercharged LT-1?
