Re: Question about cam install
Old Dec 24, 2001 | 04:54 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Question about cam install
On the L98 style roller blocks, is there a bearing that goes behind the retainer plate in the front? Or would it be OK to install it with just the plate?
KM
Old Dec 24, 2001 | 10:22 PM
mountainmotor's Avatar
mountainmotor
Default Re: Question about cam install (88-406)
There is no bearing .Are you using a roller cam in this block?
Old Dec 24, 2001 | 10:43 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Question about cam install (mountainmotor)
yes, I am using a roller cam.
KM
Old Dec 25, 2001 | 01:31 AM
JAKE's Avatar
JAKE
Roller cam blocks don't use a bearing behind the plate. Non-roller blocks need the bearing since they don't have a plate to limit rearward movement of the cam.
There are basially two type of bearings for the Non-roller blocks- One type is a single brass or copper type that looks like a BIG washer; the other type is actually a three piece set,Torrington bearing type, which is the best one to use.
The Non-roler blocks also need a thrust bumper in the front of the cam to limit forward movement. There are two type of these too; one a fixed, solid type and the other has a roller bearing (which is the best one to use).
Hope this helps.
Jake
Old Dec 26, 2001 | 08:46 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Question about cam install (JAKE)
I have to agree. No bearing in the front for the Roller cam. Just the retaining plate. Just installed the 219 two days ago.
To Re: Question about cam install
