Rusty cam
Old Jun 30, 2008 | 04:31 AM
ToniH's Avatar
ToniH
Default Rusty cam
I bought a new cam and it was rusty right out of the box. Very little storage grease on it. Well, too heavy object and too far away to send it back so looking for options. What do you say - is this a major problem or only cosmetical?
Luckily bearing surfaces have absolutely no rust. Lobes and spaces between them have some. Cannot feel them with a fingertip but can sense the roughness with my fingernail.
Here is a image to show the problem. Note, that I have increased contrast on the image so its not that bad with naked eye. Also all uneven things which are metal color are in fact oil.
So, what is the best course of action:
1. emery cloth + oil
2. take it to machine shop for repolish
3. scrap it
4. something else?
Thanks!
Old Jul 2, 2008 | 04:18 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I mighttake some 1000 grit sandpaper and oil to it. If it's too deep, I would consider scrapping it. You don't want the rust to go deeper than the hardened layer. You might be able to just put it in and let it polish itself. Use good molybdenum cam lube on the lobes before installing.
Hopefully someone will chime in for another opinion. You can also e-mail comp cams for their opinion.
Old Jul 3, 2008 | 11:05 PM
robert miller's Avatar
robert miller
If what ever you do to the thing if it put any pits in it scap it..Dont want that come off in the motor, getting into the bearings..
Old Jul 5, 2008 | 07:27 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Since it's a steel billet cam...just polish it with some scotchbright and light solvent (parts washer) and get it all off there..even in between the lobes. Should work fine as long as there aren't actual pits in it.
JIM
Old Jul 5, 2008 | 09:33 PM
Ironcross's Avatar
Ironcross
JIM
with this opinion
Old Jul 11, 2008 | 08:07 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
I disagree with all the above.
The rolling contact between the cam lobes and the roller on the lifter generates huge stresses in the camshaft that can lead to fatigue and flaking of the cam surface, and that would be greatly accelerated by any deviation from a polished finish.
You should send your fine color photo to the vendor and insist that he pay for shipping this piece of junk back to him, and that he personally inspect and grease up the replacement he will be sending, again at his expense. Don't let him get away with this.
Old Oct 26, 2008 | 11:19 PM
MikeNKalibs6t7Coupe's Avatar
MikeNKalibs6t7Coupe
Default cam
If you bought from a reputable vendor then I agree with the clevite kid if you got it from ebay or some other venue then I would polish it and run it but with careful inspection of the filters/magnetic drain plug with the first few oil changes to see any evidence of deterioration of the cam.
But hey what do I know, most of my engines are shade tree mechanic rebuilds so I am not out much if they destroy themselves in a hurry.
Old Oct 30, 2008 | 02:29 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Have it reground or trash it.
U need to find a cam mfr that can regrind it for you. U may have a cam mfr locally that would do this for minimal charge. This will reduce the lift but hopefully save the cam. Just too much work in replacing the camshaft to try a bad surfaced cam and have it wipe a lobe sending micro metal particles throughout the rest of the motor.
cardo0
Old Oct 30, 2008 | 11:10 PM
danno85's Avatar
danno85
cardo0
Why does regrinding the cam reduce the lift?
Old May 1, 2009 | 11:53 AM
industrialcamshaft's Avatar
industrialcamshaft
2nd Gear
Default Camshaft regrinding polishing
3. scrap it
4. something else?
Thanks!
If it doesn't clean up with some 1500 grit sandpaper, take it to a shop and have it polished. We have been grinding cams since 1970. If there's a shop in your area they might not even charge you for it.
Kams, Inc. industrial camshaft regrinding, design, and manufacturing
Old May 1, 2009 | 11:55 AM
industrialcamshaft
2nd Gear
Default Cam regrinding - profile changes
cardo0
The lift is not reduced. The exact same profile is ground back on the cam, just slightly smaller than it was initially.
Kams, Inc. - cam grinding and remanufacturing for industrial engines
To Rusty cam
