Time to fire it.
Old Dec 30, 2001 | 04:46 AM
The Dude's Avatar
The Dude
Default Time to fire it.
Just have to fill with coolant, put in some gas, prime it, stab in the distributor and twist the key. Let's have a non-poll. I figure there are 7 things that can leak. What's it going to be:
Oil
Coolant
Fuel
P.S. Fluid
Trans Fluid
Exhaust
Vacuum
Old Dec 30, 2001 | 05:06 AM
1979toy's Avatar
1979toy
Default Re: Time to fire it. (The Dude)
The short answer is: Yes!
Glad to hear that you're about to enjoy the fruits of your labor.
Old Dec 30, 2001 | 10:53 AM
kellsdad's Avatar
kellsdad
In my case, it was fuel and exhaust. I hope yours is leak free.
Old Dec 30, 2001 | 11:28 AM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Time to fire it. (kellsdad)
What year Corvette is it? If it is a C3 I would say vacuum, as there is about a mile of vacuum lines on em :D . Oil will be my second choice :smash:
AC
Old Dec 30, 2001 | 10:28 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Time to fire it. (A C)
Another vote for OIL!!! :U
Old Dec 31, 2001 | 02:42 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
If you did it right, NONE of the above :)
Old Dec 31, 2001 | 02:43 AM
The Dude's Avatar
The Dude
Default Re: Time to fire it. (LPDesRoche)
Seems like the consensus is oil or vacuum. This has been a long time coming--I blew up my last engine on April 22 and this one has been under construction since about June. Long story.
It's a forged 406 (Eagle crank and rods, SRP pistons). It's got Dart Pro-1 215 c.c. heads. Pistons are .008" in the hole at TDC and with the .039" head gasket the quench is .047" This gives about 10.4 static compression. The cam is a Crane Powermax solid (244/252 duration at .050 and .518"/.536" lift with 1.5 rockers. On top is a Holley Strip Dominator manifold--courtesy of a very smooth transaction with a forum member--and an 800 CFM Holley D.P. carb. (That intake/carb combo fits under a stock '76 hood if you use one of those Edelbrock signature series air cleaners because they come with a dropped base.)
The weak links are (1) the headers--1 5/8" primaries into 3" collectors and 2 1/2" duals; and (2) the rear gears--3.08.
It's probably going to be a little doggy at lower RPMS but it should pull to 6,500-6,800 easy. I think I'll be shifting into 3rd about 100 feet before the traps. :lol: Hey, it'll work for now.
Old Jan 5, 2002 | 05:29 AM
GlockLT4's Avatar
GlockLT4
My vote is coolant... but i cheated :jester
To Time to fire it.
