SBC 400 crank
Old Sep 28, 2008 | 07:33 PM
61LS6's Avatar
61LS6
Default SBC 400 crank
I have a 400 ci SBC engine with a standard crank. I intend to build the engine to 406ci and about 450hp. Will the existing crank holdup or should I replace it and if so what is a good choice?
Thanks in advance, Bill
Old Sep 28, 2008 | 10:38 PM
sly vette's Avatar
sly vette
From what I have heard in the past,I would think that anything other that a nodular iron crank would work. But I will defer to those with more knowledge than myself.
Old Oct 2, 2008 | 05:35 PM
Deakins's Avatar
Deakins
As long as it's no more than 10 under on the rods and mains it should be fine; I have even seen some of that hold up without issue but I wouldn't try it...
Old Oct 2, 2008 | 10:07 PM
ylose's Avatar
ylose
Some of the standard cranks were forged.......have you torn down the 400 yet (disassembled)?
Old Oct 6, 2008 | 09:54 AM
61LS6's Avatar
61LS6
I have the engine torn down
Old Oct 6, 2008 | 10:23 AM
cv67's Avatar
cv67
St. Jude Donor '05
Deakins.
Old Oct 6, 2008 | 11:21 AM
billla's Avatar
billla
St. Jude Donor '14
It's within range for the crank, certainly. It kinda depends on your budget and usage - do you plan to spray or use forced induction?
The more significant concern is the block - is it a 2-bolt or 4-bolt main? The 2 bolt is fine for this application with studs (and an align-hone), but the 4-bolt would be questionable...they're the opposite of 350 blocks due to the thin outer caps.
If this is a big-dollar engine, plan on spending the $600 or so to get steel 4-bolt caps.
To SBC 400 crank
