Sprotsman II heads
Old Jan 15, 2002 | 01:18 PM
68 Roadster's Avatar
68 Roadster
Default Sprotsman II heads
Will this combo work well: Sportsman II heads, Performer RPM Air Gap and a Holley 4150 on a 350 Chevy?
Old Jan 15, 2002 | 11:03 PM
1979toy's Avatar
1979toy
Default Re: Sprotsman II heads (68 Roadster)
If the carb that you are going to use is between 600 and 750 CFM then yes the parts that you have listed will give you a good performance boost. Did you plan on installing a high performance cam too?
You are going to have a lot of work ahead of you to get the set up under a stock height hood.
Old Jan 17, 2002 | 08:00 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
While I was biulding my motor, my engine builder recommended the Sportman II's with my RPM cam and intake. I have about 10.25:1 compression with zero deck clearance in my SBC 355. I've been very pleased with the results :) . The Sportman II's are said to be a very economical head choice for drag racing, being able to support a 500hp SBC.
Old Jan 17, 2002 | 04:40 PM
nunus79's Avatar
nunus79
Based on 1/4 mi mph results, the Sportsman IIs alone netted me a 55 horsepower gain over stock fresh rebuilt smog heads. They advertise a 30-70 bolt on gain.
The RPM manifold uses the same 1205 gasket size as recommended for the Sportsman II. So the intake ports should match-up real well.
Put in a decent sized cam and you are off to the races!!!!
PS Even if you are not going to play on the strip, this combo should be real streetable too.
[Modified by nunus79, 10:42 AM 1/17/2002]
To Sprotsman II heads
