74 Semi-Pro Tourer
Old Jan 20, 2002 | 05:15 PM
Ricisan's Avatar
Ricisan
Default 74 Semi-Pro Tourer
I want to give everyone the opportunity to get in their opinon on how well my car will preform. I have gathered much of my plan from here. So I am interested in what the Forum members think my car will do.
360 sb. 10.25 cr. TFS heads pocket ported w/backcut valves. CC 218-224 Hyd Rol + 1.6 rr = 529- 539 lift.
Air gap port matched, 750 Deamon "too rich right now"
FORGED crank, pistons and 6 in rods.
3.55s, M21 . 245-15s.
I want to join the 12 Second 20 MPG Club. Will this do it?
Old Jan 20, 2002 | 05:36 PM
mountainmotor's Avatar
mountainmotor
Default Re: 74 Semi-Pro Tourer (Ricisan)
I don't think that with using the 6 inch rods you will get there with out changing the rear gear ratio .You are using a cam that is a bit on the small side as well but it has made a 12 second pass before!
I bet you will enjoy the power it makes though
Old Jan 20, 2002 | 07:46 PM
vettedave's Avatar
vettedave
You might get into the high twelves but without fuel injection or a perfectly
tuned Quadra jet (wich has small primaries) I doubt 20 mpgs . :nonod:
Old Jan 27, 2002 | 11:42 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: 74 Semi-Pro Tourer (vettedave)
High twelves on slicks, need better gears. Not going to make 20 mpg. Nice street car. :chevy
Old Jan 31, 2002 | 01:46 PM
SteveG75's Avatar
SteveG75
Default Re: 74 Semi-Pro Tourer (69 N.O.X. RATT)
Kind of like mine except I am using the flat tappet cam (XE262) is lift is only .493/.500 with 1.6 rockers. I was able to get 20 mpg with the old mods and I think the more powerful engine balanced with the ROD 6 spd I ordered will really help (3.36 rears). With that 3.55, you really need some kind OD transmission. :smash:
To 74 Semi-Pro Tourer
