1984 c4 350ci
Old Jan 16, 2009 | 03:58 PM
Dtroyder's Avatar
Dtroyder
3rd Gear
Default 1984 c4 350ci
I bought this 84 knowing the engine had a loud knock. Took motor out and disassembled. Now I see I need new heads the 624s are cracked. Any ideas or suggestions for casting numbers that would be a solid replacement? Not looking to spend a ton but would like to improve horse power if it's not to costly. thanks Bob:
Old Jan 22, 2009 | 08:27 PM
64_365's Avatar
64_365
Find a set of 86 to 89 aluminum heads. Should be relatively cheap.
Old Jan 24, 2009 | 02:00 AM
Curveit's Avatar
Curveit
They (L-98) will raise your compression a good bit as they only have a 58 CC Combustion Chamber. I don't know if it will be too high or not. Post on C4 Tech or try the Crossfire site for info.
Old Jan 26, 2009 | 05:39 AM
64_365's Avatar
64_365
You say that like it's a bad thing.....
To 1984 c4 350ci
