Compression Ratio Guess?
Old Jan 27, 2009 | 01:04 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Default Compression Ratio Guess?
Before I go any further, I wonder if anyone could venture a guess as to what CR I may have here:
327 bored 0.040" over
Block height 9.005"
Crower Sportsman Rods 5.7"
TRW Flat-top Pistons #L2165F
Edelbrock Performer RPM Heads #60899 64cc
Head Gaskets FelPro #7733PT2 0.039"
My goal is 10:1. Is this in the ball park? Thanks for any positive input.
Dave
Old Jan 28, 2009 | 05:08 PM
Dave64's Avatar
Dave64
ttt
Old Jan 28, 2009 | 07:56 PM
leadfoot2's Avatar
leadfoot2
Assuming orig bore and stroke was 4" x 3.25" and there are no valve reliefs in the pistons and the top of them are even with the deck you have about 10.4:1.
Old Jan 29, 2009 | 10:04 AM
Dave64's Avatar
Dave64
Thanks Leadfoot. I guess I'm int the ballpark as planned. Take care.
Dave
Old Jan 31, 2009 | 09:00 AM
64_365's Avatar
64_365
Pi r square, cornbread are round.
Old Feb 2, 2009 | 01:37 AM
Cris's Avatar
Cris
Dave:
No reason to guess at your compression ratio. If you aren't handy with math there are several on-line compression-ratio calculators. Here's a link to one of them:
http://www.csgnetwork.com/compcalc.html
After a quick search I found your TRW L2165F pistons have a pin height of 1.671 inches. This leaves the piston (at top dead center) .009" inches below your deck of 9.005". The L2165F pistons also have valve reliefs that create an extra 5.4cc volume. The felpro gasket you are using has a bore of 4.125".
Plug that all into a calculator and you get a compression ration of 9.6:1
Old Feb 2, 2009 | 09:00 AM
lackomotorsportsllc's Avatar
lackomotorsportsllc
I agree with Cris
never guess always calculate.......numbers dont lie!
Old Feb 4, 2009 | 01:19 PM
Dave64's Avatar
Dave64
Thanks guys. I can live with 9.6. It's not 11.5 the motor is supposed to be, but it will be a driver that will accumulate many miles. I just hope the crisp sound is still there. I know it won't really be the same, but at least it will be solid lifter crisp. Thanks again.
Dave
To Compression Ratio Guess?
