would it be possible
Old Mar 3, 2009 | 05:14 PM
Belgian1979vette's Avatar
Belgian1979vette
Default would it be possible
To use an automatic trans coupled to the engine and with the output shaft connected to a torque arm, to work as an engine brake ? I would like to experiment building a home build dyno that way to lug the motor in order to do some tuning on my efi system.
Old Mar 13, 2009 | 12:06 AM
gkull's Avatar
gkull
Yes you could put a load the same thing as power braking a motor at the starting line.
my engine dyno at work is basically a water pump that measures the bending force applied to the pump housing
